Author Topic: Welds  (Read 844 times)
Offline Lunchbox
Welds
« on: January 17, 2007 - 01:26:18 PM »
What is the trick to reproducing spots welds with a MIG welder?
What is the best way to dress welds on your car. i.e. MIG plug/spot welds or stitch welds? What products and tools are you using?
Thanks
Lunch
Offline ShelbyDogg
Re: Welds
« Reply #1 on: January 17, 2007 - 01:46:23 PM »
I learned this Tony (fishin4cuda),  Grind it down almost flat, then after spraying primer, push in a pencil eraser and give it a slight twist
Offline Lunchbox
Re: Welds
« Reply #2 on: January 18, 2007 - 09:48:32 AM »
Thanks anymore  :feedback:
Offline R/T hedkace
Re: Welds
« Reply #3 on: January 20, 2007 - 12:45:15 PM »
Good question lunch, since I'll be doing the same very soon.  :thumbsup:
Unfortunately we only have one welder out of 4582 members apparently  :walkaway:  :feedback:
Thanks shelby, even though I have no idea what your talking about  :roflsmiley:
Jeff
    Defending the Earth from "uptight" mods!!   an endless crusade..........
1970 Dodge Challenger R/T 440 4speed Dana
1970 Dodge Super Bee
1969 Barracuda
 Massachusetts
Offline Challenger6pak
Re: Welds
« Reply #4 on: January 20, 2007 - 04:56:24 PM »
 To put it another way he is saying that he alters the look of the primer with the eraser to make the weld look like it is a spot weld instead of a weld from a mig. This is done in wet primer. It's a great idea.
Re: Welds
« Reply #5 on: January 20, 2007 - 05:23:23 PM »
Offline aussie-e-body
Re: Welds
« Reply #6 on: January 23, 2007 - 10:33:19 PM »
guys ,i use a center punch with the point ground off to reproduce spot marks.i usually punch the spot between the plug holes before i fit the part or it can be done after .you need to have a dolly behind of course either way you choose to do it.very simple and effective.and it also creates a slight gap between the panels so when i drown it with POR15 it seeps through and seals everything...........
i want it all-i want it yesterday-and i want it for nothing
Offline Lunchbox
Re: Welds
« Reply #7 on: January 24, 2007 - 01:04:31 AM »
Good post and links guys this was exactly what I was looking for.   :2thumbs:
