Author Topic: how do i see if my car is matching numbers?  (Read 1505 times)
Offline JasonTx
« on: January 17, 2007 - 11:57:49 PM »
I have one more question. How do i check just to make sure that my car is matching numbers? WHere on the engine do i look and what numbers do i match? Sorry for all the questions.
Thanks Jason
Re: how do i see if my car is matching numbers?
« Reply #1 on: January 18, 2007 - 12:43:46 AM »
there should be 6 #s , the dash , stamped on the top left of the cowl , the top left of the rad support , the fender tag , the block should be behind the right engine mount just above the oil pan & on the right side of the trans case , different locations depending if it is auto or 4 spd but on a flat pad
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #2 on: January 18, 2007 - 08:32:11 AM »
engine and tranny loctions as illustrated...
Offline JasonTx
« Reply #3 on: January 18, 2007 - 10:45:05 AM »
its a automatic.
Thanks for the help.
Offline JasonTx
« Reply #4 on: January 18, 2007 - 02:14:07 PM »
what numbers do i match that tag to on the motor to? The vin or the fender tag or what? Like what numbers need to line up or are they the same number?
« Reply #5 on: January 18, 2007 - 03:52:07 PM »
The numbers on the motor will match the ending sequence of numbers of your VIN. The motor will also have the numbers for the date code on it. They are pretty much impossilble to see if your car has headers on it. At least that's the case for a big-block.
Offline JasonTx
« Reply #6 on: January 18, 2007 - 04:57:43 PM »
ok thanks. Lucky for me the car still has the original exhaust mainifolds.  It is a all original car.  91k miles and still has the granny hub caps ( lol )   .     It looks like a granny car. But it is a 1970 barracuda grand coupe.
Thanks Jason
Alaskan_TA
« Reply #7 on: January 18, 2007 - 08:11:01 PM »
This article will walk you through all the places to check;
http://www.aarta.com/numbers_matching/numbers_matching.html
Offline Street_Challenged73
« Reply #8 on: January 18, 2007 - 09:19:58 PM »
Here are 5 of the 6 numbers on mine. (the engine stamping doesn't match as it's the 340 I'll be dropping in.)  Hopefully it'll help you with what you should be looking for on yours. :2thumbs:
« Last Edit: January 18, 2007 - 09:22:08 PM by Street_Challenged73 »
Offline JasonTx
« Reply #9 on: January 19, 2007 - 05:35:47 PM »
Thanks Alot guys. I am going to make sure everything matches as soon as the weather gets better.
Thanks again Jason
