Author Topic: Just Suspension - Ground Pounder  (Read 3178 times)
Offline Ornamental
  • Oslo, Norway
« on: January 18, 2007 - 10:00:10 AM »
Anybody got an opinion on the Ground Pounder from Just Suspension?
Keep your rear wheels firmly planted on the ground with our new "Ground Pounder" rear axle set up.
With the shocks mounted at 90 degrees to each other this kit is designed to reduce rear axle wind up and axle hop while stabilizing the pinion angle.
With the ground pounder you're sure to have a decrease in launch times.
Our Ground Pounder kit consists of the following items:
Heavy duty six leaf springs
Four shocks
Shock mount plates
Four U Bolts
Heavy Duty Shackles
Rear poly bushings
The "Ground Pounder" A,B or E body Cars...$995.00.00
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Offline 4Cruizn
  • HEMI FISH
Re: Just Suspension - Ground Pounder
« Reply #1 on: January 18, 2007 - 01:11:44 PM »
I'm interested too as I've seen it for sale in the annual mopar mag as wondered if anyone has used it??   :popcorn:
« Reply #2 on: January 18, 2007 - 01:22:03 PM »
the idea is sound ,but I am not sure how much difference it will make
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
« Reply #3 on: January 18, 2007 - 08:06:48 PM »
Any interfearance problems with larger (wider) tires?
{oo/===\oo}
Offline GMachineDartGT
« Reply #4 on: January 25, 2007 - 11:16:08 AM »
Whats worse than 2 KYB shocks in the rear, its four KYB shocks...Ehrenberg did this on the green brick years ago. Get an 80's 5.0 mustang and grab the kicker shocks and brackets off them. We used to take them off all the time back then...
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #5 on: January 25, 2007 - 01:54:54 PM »
 :popcorn: :popcorn:
