Author Topic: Sending unit  (Read 1231 times)
Offline TreeFrog
    • TreeFrog
Sending unit
« on: January 18, 2007 - 02:23:48 PM »
I am looking at a sending unit for my 73 Challenger.
it has a 5/16 but I want to put a 3/8 in (who knows what could go in the car)
as I recal my sending unit does not have a return...the 3/8 advertised does..
were they different, or do you just cap off the new ones if you don't use it...etc.
Help?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Re: Sending unit
« Reply #1 on: January 18, 2007 - 04:06:22 PM »
Interesting.  :screwy: I haven't seen a 3/8 sending unit with a return line. Are you sure this is for an E-Body? They were for 440 and Hemi cars. I suppose there is no problem capping, or plugging the return nozzle if you don't need it. I want to caution, to get the full benefits of a 3/8" sending unit, you need a 3/8" line all the way to the fuel pump, then to the carb. Unless you plan on dropping something in that has well over 400HP, I would leave the 5/16" sending unit in there.
Re: Sending unit
« Reply #2 on: January 18, 2007 - 04:08:29 PM »
the return line port can be just capped off
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Sending unit
« Reply #3 on: January 19, 2007 - 12:18:30 AM »
That is what I did to mine.
Offline TreeFrog
    • TreeFrog
Re: Sending unit
« Reply #4 on: January 19, 2007 - 05:46:35 AM »
I plan to change the line out later, but not at this time.
I doubt I will ever change the sending unit again....how offten does one go bad.
The only reason I am planning on changing it out now is based on the fact that I have to change the tank.
Offline Jacksboys
Re: Sending unit
« Reply #5 on: January 20, 2007 - 10:06:16 PM »
As long as it is made well, it should last you many many years, just like the originals that are still being used today.
