Author Topic: 4 speed conversion  (Read 8151 times)
Offline 1973challenger360
4 speed conversion
« on: September 11, 2003 - 04:25:55 PM »
what does it take to convert to a 4 speed,
bellhousing, drive shaft, shifter, tranny, clutch petal, clutch, flywheel.
I I find any vehicle with a 4speed, can I use all the parts, besides petals, truck tranny its self ( no granny ) shifter, drive shaft
are the other parts interchangeable ?
Re:4 speed conversion
« Reply #1 on: September 11, 2003 - 08:28:36 PM »
also who makes a 4 speed hump ?
Offline b5blueaar
  • Mad Max Cuda
« Reply #2 on: September 11, 2003 - 10:57:45 PM »
 Also need a clutch "z" bar linkage (ebay about $30), and its pivot bracket that mounts to the drivers side frame rail (can get this bracket aftermarket about $25), and a firewall reinforcement bracket that spans two of the holes where the pedal assembly mounts to the firewall to stiffen the firewall (ebay about $20).
The hump is becoming available any where you can buy repo sheetmetal, usually runs about $130. Used humps on ebay go for about $100. Spend the extra 30 and get a new one. Let me know where you get it and if it fits good. The floor in the area where it welds has a lot of contours and if it is not reproduced correctly it could be a nightmare trying to get a good fit.
I am currently collecting parts to convert my 71 to 4 spd.
« Reply #3 on: September 11, 2003 - 11:43:17 PM »
I have not decided what tranny to install behind my 360
I would like a 5 speed but not seeing that happening anytime sone.  so either a 904, 727 or 833.  Just looking into parts needed,   If I purchase an A, B, C, F can everything besides petals and drive shaft swap in or a truck driveshaft petals and tranny
will 3speed parts fit a 4 speed       bellhousing or flywheel ?
I assume everything else will work..
Offline mustardketchup
  • I'm a llama!
« Reply #4 on: September 11, 2003 - 11:57:24 PM »
1973challenger360, I'll answer what I can:
*First, pick your trans.  It will need to have a B/E body tailshaft (dual mounting locations) to fit your Challenger.
*Now you have to match your clutch/pressure plate selection to the input spline count of your trans (either 23 spline or Hemi 18 spline trans (much more $$ for the Hemi box)).
*Your flywheel choice will be dependant upon your clutch selection (Clutch/pressure plate types: 10.5, 10.95, or 11 inch; diaphram, borg & beck, or long style).
*Your bellhousing will have to fit your flywheel/clutch/pressure plate assembly - 10.5 & 10.95 vs. the 11 inch set-ups.
*Buy a shifter, either aftermarket or a used Chrysler E-body Pistol Grip.  But c'mon, we're Mopar people here, so a Pistol Grip is the cool looking way to go.  You will also need the shifter rods and the shifter rod lever "tabs" and small hardware for the shifter rod linkage.
*Get an E-body pedal set-up.  I don't know if any B or A body stuff will work in an E-body, so maybe somebody else on this board can answer that.
*Get a clutch torque shaft (also known as a Z-bar in GM language).
*Frame brackets for the torque shaft
*Get the clutch rod kit and release bearing lever kit from Mopar Performance.  There are differences between small and big block kits, so get the right one.
*Cut the floor out carefully to fit your used or new manual transmission hump.
*I don't have my reference books with me, but I think you need a longer driveshaft for a manual trans.  Mopar Peformance sells kits that you will have to have cut/balanced at a drivetrain shop.  Or you can search the swap meets.
*You will have to make sure your crankshaft has been drilled out for the pilot bushing required for the input shaft of the manual trans.
     Now, where do you get this stuff.  Beside the aforementioned swap meets searches, you can try the usual restoration sources such as Jim's Auto Parts, Koller Dodge, Mancini's, Jack's Auto Parts, Layson's, Year One, or the Paddock.  But for my transmission specific needs, I would try:
*Brewers Performance, Inc at 937-698-4259.  They have things like small rebuild parts for transmissions, shifter linkage kits, torque shafts, floor humps, shifters.
*Imperial Services at www.imperialservices.net or at 989-652-6309.  They seem to have the smaller bits and pieces for the shift linkage.  Check 'em out thoroughly, because I did not get the chance to.
*Keisler Automotive Engineering.  They can sell you everything you need to go from an automatic to a 5 or 4-speed set-up.  They sell everything the first two guys sell as well as pedal set-ups.  From Richard Ehrehnberg's articles in Mopar Action, these guys look to have high quality stuff.
*Auto Body Specialties (www.autobodyspecialt.com or 888-277-1960) for a transmission hump.
*Harms at www.surprisegarage.com for shifters, trans humps and other stuff.
     I hope this helps.  If any other people on this site can offer additional advice, correct my mistakes, mention other suppliers, or sell you the stuff you need, please step up to the plate.
Larry
« Last Edit: September 12, 2003 - 12:10:49 AM by mustardketchup »
« Reply #5 on: September 12, 2003 - 01:00:26 AM »
thanks for the help, great imfo
« Reply #6 on: September 12, 2003 - 02:20:45 AM »
well written Larry
 Mostly accurate , the 71 & up B body pedal will work in an E body , The driveshaft remains the same lenght
« Reply #7 on: September 12, 2003 - 12:23:46 PM »
71 and up, what was the last year for the b-body will they all work ?
« Reply #8 on: September 12, 2003 - 01:06:41 PM »
Sorry 71 -74 will work , I have never seen a 75 up 4 spd car
« Last Edit: September 12, 2003 - 01:07:35 PM by Chryco Psycho »
