Author Topic: Rear axle gears  (Read 2932 times)
Offline Srobinson4
Rear axle gears
« on: January 18, 2007 - 08:35:35 PM »
I converted my 727 to a A833.  I don't nave much knowledge about rear ends.  What gear ratio would make this car quicker off of the line with out sacraficing streetability.  It is currently a 340 car with a standard rear end.  Please assume everything else works properly.
SRR
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Rear axle gears
« Reply #1 on: January 18, 2007 - 09:16:25 PM »
With small blocks I like to run 3.91  gears or lower even with an automatic, and 3.55 for big block cars. Also streetability is a relative term, highway driving is what will really determine how low you should go.
1996 Dodge Viper GTS Coupe
Re: Rear axle gears
« Reply #2 on: January 19, 2007 - 12:32:38 AM »
there are a # of options here , if you use the OD 833 4 spd when you convert 3.91 would be my choice , as you will have tons of low end power & still have around 2.80 for the highway , if you are going to a regular 833 3.23 or 3.55 aree good all round gears , it really depends what you want the car to do & how much time you spend cruzin , city commuting or highway driving
Offline Srobinson4
Re: Rear axle gears
« Reply #3 on: January 19, 2007 - 05:12:43 AM »
It it your opinion that the 3.91 will allow for no problematic highway driving?  Is there a middle ground between the 3.91 and the 3.55?  If so your thoughts please.
SRR
Re: Rear axle gears
« Reply #4 on: January 19, 2007 - 09:01:57 AM »
there is a 3.73 available for the 8 3/4 diff
 persoanlly I would not choose 3.91 with any significant amount of highway driving Inless I was using the 833 Od trans
Offline Srobinson4
Re: Rear axle gears
« Reply #5 on: January 23, 2007 - 08:37:37 PM »
Does the fact that I am running 17"x7 front and 17"x8" rear magnum wheels on the car create issues with rear axle gearing?  For this set up what gears would you run?
SRR
Re: Rear axle gears
« Reply #6 on: January 23, 2007 - 11:25:56 PM »
 The overall diameter of the tire & wheel combination would have to be similar so no it doesn`t effect the gearing
Offline 72hemi
Re: Rear axle gears
« Reply #7 on: January 23, 2007 - 11:39:47 PM »
I drive my small block with 3.91 on the freeway all the time with no problems, but I don't usually cruise down the freeway at 80 mph in that car though.
Offline Srobinson4
Re: Rear axle gears
« Reply #8 on: January 24, 2007 - 05:02:41 AM »
I don't have the A833 OD therefore I am taking your advise and going with the 3.55.  Can you suggest any vendors?
SRR
Re: Rear axle gears
« Reply #9 on: January 24, 2007 - 09:55:19 AM »
are you just looking to buy the gear set or do you want the whole center section already set up?
Offline Srobinson4
Re: Rear axle gears
« Reply #10 on: January 24, 2007 - 11:05:37 AM »
Just the gears.
SRR
Re: Rear axle gears
« Reply #11 on: January 24, 2007 - 11:47:35 AM »
Summit , Jegs , Mancini are probably as cheap as anyone , should be in the mid $200 rpice range
 Strange , Motive , Eaton ,Richmond are all good makes
« Last Edit: January 24, 2007 - 01:11:20 PM by Chryco Psycho »
Offline Srobinson4
Re: Rear axle gears
« Reply #12 on: January 24, 2007 - 04:31:51 PM »
Thanks for all help.
SRR
Offline vinb
Re: Rear axle gears
« Reply #13 on: January 24, 2007 - 06:49:12 PM »
3.55 would be a good choice. 28" rear tire 275/60/15. I ordered mine from Summit and are Motive Gears, on back order from 3 weeks, should have them by the 30th. Never used Motive before so I like to try something different....Vin..
Offline 1970hemicuda
Re: Rear axle gears
« Reply #14 on: January 26, 2007 - 09:18:15 AM »
SRR
A 3.91 with 28" tires would effectively give you something in between ~
