Hey,
I just hooked up the battery and now have the ability to bump the starter to crank the engine vs. the manual way with a socket. I can now button up the front end. I need to know the correct hardware for 70 440 w/o AC, and PS. The Bolt I have in the pic on the paper I believe is correct (slotted head, course thread) Does this bolt that connects the fan clutch, pulley and water pump housing need a washer of some sort? Also, I've seen a metal shim piece that goes between the pulley and fan clutch. Is that needed? Also, I've had this fan clutch around for a number of years, can it be tested to see if it is good? If not, does mother mopar still offer them? I know lots of questions, but I want to button up the front end this weekend. Thanks JOhn
