Author Topic: How do you restore door panels  (Read 16059 times)
Offline r15303
Re: How do you restore door panels
« Reply #30 on: January 27, 2007 - 08:20:48 AM »
 :popcorn:
« Reply #31 on: January 27, 2007 - 08:21:26 AM »
Mike I received the SEM chart last night.  I will match up the colors and send it back to you sometime in the next couple of days.
Thanks,
Walt
Walt,
  Take your time. I'm interested in knowing what shade of white you go with.
Offline Challenger6pak
« Reply #32 on: January 27, 2007 - 08:57:46 AM »
  If someone has white interior, can you post some pics.  It would be great to see pics of a white ragtop plum crazy r/t chally with white interior.  Thanks
Here's some pics 70 RagTop.  My 71 is factory purple with white.  I will redo it that way.  I do not know who owns these cars.
« Last Edit: January 27, 2007 - 09:00:23 AM by Challenger6pak »
Offline 70RAGTOPR/T
« Reply #33 on: January 28, 2007 - 11:31:07 AM »
Thanks 6pak.  Your pics give me a reference point.
Walt
Offline Winston
« Reply #34 on: January 30, 2007 - 02:02:56 PM »
I have called a couple of local autobody shops.  I found one that sells the SEM paint dye, but they do not sell SEM prep promoter.  However, they do sell adhesion promoter made by a company called Bulldog.  He said it is the same kind of stuff.  Does anyone have any experience with the Bulldog brand, or should I order the SEM stuff over the internet?
Offline r15303
« Reply #35 on: January 30, 2007 - 02:50:04 PM »
I'd go with the SEM myself - it works great!   Super white is your color!
Offline Tropicalcats
  • Don't Ever, Ever Give Up
« Reply #36 on: January 30, 2007 - 04:49:25 PM »
I have used the SEM product line and was very happy. The Bulldog line might be just as good but I would stick with the same brand and not mix and match.
SOLD
Offline Winston
« Reply #37 on: January 30, 2007 - 05:56:44 PM »
OK will do.  I called someone else here locally who will order me the correct products I need.  To do this correctly, Do I have to use the SEM soap, or can I use regular soap to clean the panels?  Also, can I buy only the adhesive spray and the dye?  Is Landau Black the correct color for the normal black panels?
« Reply #38 on: January 30, 2007 - 07:13:41 PM »
I would and have used the SEM soap and would stick with that.
Landau Black is the correct color for black panels.
SOLD
Offline 70_challenger
  • Suburban Detroit, Michigan
« Reply #39 on: January 30, 2007 - 08:13:03 PM »
I haven't used the SEM soap, but I'm sure it is a top-notch product.  (I just scrubbed mine with dishsoap/water and a Scotchbrite pad).
Yes, the Landau Black is correct, and will look great.
Tom
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #40 on: January 31, 2007 - 08:20:00 AM »
I have heard of other people not using the soap and it turning out fine.  Just make sure you get it really, really clean with all oil/grease removed.  Wash it 4 times if you have to...prep is everything with this.
Offline Winston
« Reply #41 on: January 31, 2007 - 08:29:57 AM »
OK, I ordered the following:
1 SEM Soap
1 SEM Plastic/Leather Prep
2 SEM Plastic Adhesion Promoter
3 SEM Landau Black Dye cans
Should this be enough for 4 interior panels and 2 seatbacks?
70RAGTOP, thanks for starting this thread.  The info on it from everyone has been very helpful.  Thanks everybody!   :wave:
Offline Rev-It-Up
  • Global Moderator
« Reply #42 on: January 31, 2007 - 10:30:40 AM »
1 SEM Soap
Yep, that should do it! Please take before and after pics...I love them.  :grinyes:
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #43 on: January 31, 2007 - 11:16:33 AM »
 :popcorn: :popcorn:
Offline Winston
« Reply #44 on: January 31, 2007 - 11:55:45 AM »
I will definitely keep y'all posted.  I'm supposed to get the products either Friday or Monday and will start the work shortly after.  It'll be my first time doing this, so I hope I don't mess 'em up!
