Author Topic: 22 to 26 rad conversion  (Read 610 times)
Offline r15303
« on: January 22, 2007 - 06:14:46 PM »
I just received my passenger side rad support for a 26" rad conversion on my 70 Chally but now I'm noticing that the driver rad support is wider than I expected.  The opening is 1/2" too narrow.  When I checked the driver side support on my true R/T car, there is a definite difference between the two driver side supports.  I thought replacing only the passenger side support would do the trick.  Any of you guys run into the same problem?  :clueless:
Offline moparnocar
Re: 22 to 26 rad conversion
« Reply #1 on: January 22, 2007 - 07:10:51 PM »
I have a friend who ran into the same problem. Notice it was just that little bit.. so he changed both sides..
« Reply #2 on: January 22, 2007 - 10:25:03 PM »
it basically goes frame rail to frame rail
Offline r15303
« Reply #3 on: January 23, 2007 - 08:05:34 AM »
thanks guys.  Moparnocar - where did your friend get the part for the left side?
