Author Topic: aluminum radiators  (Read 1664 times)
Offline conv340
    • Myspace CaMopar
aluminum radiators
« on: January 23, 2007 - 09:58:23 PM »
I'm looking for some input and ideas for aluminum radiators. I would love to see some pics of cross flow radiators installed in E-bodys. If this has already been done point me in the right direction!  :dunno:
My project is a 70' Cuda pro-touring kinda thing. Here is the link to my blog http://360.yahoo.com/brinkenterprise and under members projects "channeling a 'Cuda" It will be running a late model Hemi and want to run a cross flow aluminum radiator. I have a XV lower rad support and need to push it up as far as I can that means having a radiator in hand to make sure it clears. ( what happened to XV's radiators?) Some known issues because of the channeling. I can't use the Be-Cool set up that goes over the frame. Bill Reilly's radiator would work but doesn't make the best use of space if you have a 26" support. any experience and pic would be helpful.  :picture:
Thanks for all the great support -Bob
« Last Edit: January 23, 2007 - 10:00:14 PM by conv340 »
Two models, Two makes, One year, One body.
Offline wart1de
    • Vivah
Re: aluminum radiators
« Reply #1 on: January 23, 2007 - 10:04:06 PM »
 :popcorn:
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
« Reply #2 on: January 23, 2007 - 11:29:08 PM »
Griffin rads  has to levels , the cheap rads are epoxied together & will eventually leak , you really need to use a welded rad
Offline Tubbed440
  • Suspension NinJa
« Reply #3 on: January 24, 2007 - 06:17:17 AM »
I used one of the radiators from Summit. Northern  makes them.  They are made in the USA and are all welded construction.  Seem to be a nice piece too.  I just have started fitting it into my car (Challenger).  I can post some pics later this evening.
Here's a link to the one that I purchased from Summit.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D380428&autoview=sku
It's 27.xx wide, but the core is the exact size of the opening in the radiator support for a Challenger.
« Last Edit: January 24, 2007 - 06:18:58 AM by Tubbed440 »
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
Offline GoodysGotaCuda
« Reply #4 on: January 24, 2007 - 06:28:53 AM »
Summit ~26"
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 70B@rracuda
« Reply #5 on: January 24, 2007 - 04:39:05 PM »
What shroud and fan is that Goody?
Offline Got JOB
  • Member since 2-14-06
« Reply #6 on: January 24, 2007 - 05:32:25 PM »
mine is a Be Cool 22", stock shroud turned upside down and trimmed a bit
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline 4Cruizn
  • HEMI FISH
« Reply #7 on: January 24, 2007 - 08:22:40 PM »
Here's mine.  Griffin with a twin fan setup I bought at Ram Chargers before they went out of business.
« Reply #8 on: January 24, 2007 - 08:34:37 PM »
Off a Chevy HHR  :2thumbs:
1976 Dodge Warlock
Offline conv340
    • Myspace CaMopar
« Reply #9 on: January 24, 2007 - 10:00:49 PM »
This is good stuff.   :grinyes: I hadn't looked at house brands yet and I was poking around summit tonight. Look what I found it's a direct fit but they have done a terrible job of what it fits. I think it will be a direct bolt in on any e-body with a 26" support. The price seems fair and you can get left or right.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D380460&N=700+400304+4294924500+4294839040+4294908110+115&autoview=sku
might be cool.
Offline rusty dodge
  • 74 challenger 440-727-3:55
« Reply #10 on: January 25, 2007 - 04:10:29 PM »
I have that one, It will bolt in, you will need to trim the pass side flange an little, and if I remember you also have to drill a new hole. Remember to buy the inverted flare fittings for the trans cooler if you are to use it.
Offline conv340
    • Myspace CaMopar
« Reply #11 on: February 04, 2007 - 09:17:48 PM »
Well thanks for all the input. I did get the one from Summit and its fits ( Yes you would need to drill 1 hole ) I ended up remakeing the whole Support!  :eek4:
Offline rusty dodge
« Reply #12 on: February 05, 2007 - 11:29:23 AM »
Nice job with those inner fenders also.
Offline 70B@rracuda
« Reply #13 on: February 05, 2007 - 08:13:14 PM »
conv340,
Are you using a XV lower rad support? Also, what is the machine with the "cuda" lettering in blue in the background? Is that a weird coincidence or something?
Finally, thanks for bringing this topic up, it has helped me find a radiator.
Offline conv340
    • Myspace CaMopar
« Reply #14 on: February 05, 2007 - 08:59:24 PM »
Quote
Are you using a XV lower rad support? Also, what is the machine with the "Cuda" lettering in blue in the background? Is that a weird coincidence or something?
  :lol2: Isn't that great! Here in Ca we can no longer have "solvent" tanks. So in looking for a replacement "aqueous" parts washer. we found the Cuda brand to funny of coarse I had to have it!
Yes that is a XV lower brace. I needed to fit the rad so I could see how far up I could push the brace. It comes fairly long on the ends and would clear a factory radiator. But it hangs down below the valance. With the car sitting so low thats not good . Now it is flush with the bottom of the valance. The comparison pic is before I cut it down about 2.5"
« Last Edit: February 05, 2007 - 09:02:08 PM by conv340 »
