Author Topic: leaf spring install problem  (Read 1832 times)
Offline reflections7
  • God Bless
« on: January 24, 2007 - 05:49:26 PM »
I have new espo springs for an e body  stock ride hight XHD springs. The front hangers only go one way so there correct and new stock shackels.  The springs are 53 1/4  inches center to center. As you can see in the pic the dont seem long enough. Even if you try to jack them up like weight would be on the car.  see pics.  ???? whats wrong?
Re: leaf spring install problem
« Reply #1 on: January 24, 2007 - 06:42:13 PM »
they are not made for an A body or a SS spring are they , those are 2" shorter
 the B & E body measurement is 58"
 the A body is 54"
« Last Edit: January 24, 2007 - 06:45:02 PM by Chryco Psycho »
Offline Challenger6pak
« Reply #2 on: January 24, 2007 - 06:46:27 PM »
 the A body is 54"
:iagree: I was thinking the same thing.
  • God Bless
« Reply #3 on: January 24, 2007 - 07:35:31 PM »
here is there email reply.
The number on the end of the springs is the last three digits of your order number.  This is how we signify which spring is for which order.  To install the springs, Bolt the spring to the front hanger and then bolt the hanger to the frame.  Then bolt the spring to the axle.  This way you can use a jack to push on the axle to put weight pressure on the spring so that it will reach the rear shackle area.  Many times you cannot just put a spring up in place and bolt it in...the arch makes it necessary to compress the spring some to install it.  This will essentially lengthen the spring if you are measuring straight across.  If you have any other questions, please feel free to email again.  I've checked the specs on the springs and they are correct for your car.
« Reply #4 on: January 24, 2007 - 09:23:14 PM »
are you measuring the lenght over the curve of the spring ?
« Reply #5 on: January 25, 2007 - 03:12:13 AM »
Do you have the spring bolted around the axle yet? When you do, it will flatten out, and move back.
  • God Bless
« Reply #6 on: January 25, 2007 - 03:57:57 AM »
ok with the rear end in and the weight supported the shakels go back some.  really go back more than I  thought they would thanks.
Offline Mopar73340
« Reply #7 on: January 25, 2007 - 01:43:26 PM »
I bought 2 sets from them over the last couple years and they fit ok. I didn't have to put any weight on them to install them???   :clueless:
Offline Got JOB
  • Member since 2-14-06
« Reply #8 on: January 25, 2007 - 02:37:23 PM »
I bought a set of 1" over stock for my '74 last summer they were about the same way as yours, but I installed one side at a time and it worked out ok except the car set too high. Had to remove the short leaf on bottom and the height is just right and the ride is great.  What are the part #s. Mine were L-274-78-615.    Ricky
« Last Edit: January 25, 2007 - 02:39:11 PM by Got JOB »
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
  • God Bless
« Reply #9 on: January 26, 2007 - 09:16:19 AM »
I got them in.  The p/n I dont remember it was XHD for an ebody from springs and things.  with everything in and the car jacked from the centerr of the rear axle they seem ok.  Just havent ever had that problem.
