Author Topic: pulley trouble...  (Read 667 times)
Offline Stacked440
pulley trouble...
« on: January 25, 2007 - 11:31:31 PM »
I have a 71' 440 with all the correct brackets for alternator, power steering, and i'm putting a vintage air Sanden compressor on it...HOWEVER, I can NOT find the correct water pump pulley for the LIFE of me :pullinghair:  Does anyone have a site that has the correct water pump pulley for a 440 with power steering and air? :1zhelp:
-Kyle-
Re: pulley trouble...
« Reply #1 on: January 26, 2007 - 12:30:54 AM »
Lets see a pic of your set up. I am sure I have the stock pulley for a stock system if that's what you need.
Offline Stacked440
« Reply #2 on: January 26, 2007 - 06:47:32 PM »
alrighty, ill snap a pic tonight :picture:
-Kyle-
Offline oldkimmer
« Reply #3 on: January 26, 2007 - 10:39:38 PM »
u can get a pulley off any old big chrysler product, but if your in dire need I will ship u 1..........kim.......
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline Stacked440
« Reply #4 on: January 28, 2007 - 10:23:07 AM »
I got a pulley off a 383 but doesn't line up with my crank pulley, and is way to wide, almost rubs on the crank pulley :dunno:
-Kyle-
« Reply #5 on: January 28, 2007 - 12:36:44 PM »
On an a/c system, the water pump pulley isn't very big at all and has to be run with a specific idler pulley and a bracket that mounts to the water pump too.So the water pump has it's own belt that is driven off the crank and idler. Then you have a pair of belts running the a/c compressor and alt. Then a seperate belt for the power steering I do believe. Totaling 4 belts with 2 being a matched pair for the a/c.
