Author Topic: n00b question...  (Read 1807 times)
Offline Mr. 440SixPack
n00b question...
« on: January 26, 2007 - 09:14:32 AM »
Sorry because I am asking this but how does dana rear end work and what is posi? :clueless: :-[ I was looking over the net to get some info on this but no luck...
Thanks for your answers.
My dream: 1970 Plymouth 'Cuda 440+6 Pack/4 speed Pistol Grip/Dana 60 rearend/PS, PB/Lime Light/Shaker hood/Rallye dash...
Offline TrakHor
Re: n00b question...
« Reply #1 on: January 26, 2007 - 10:01:51 AM »
What do you mean how does it work? It's really no different than any other differential http://auto.howstuffworks.com/differential.htm Check that link out and see if it helps.
There are multiple types of posi, one of the more common ones has a disc and a friction plate. the disc will spline to the axle and the friction plate will lock in to the differential with tabs that stick out. When the differential moves the axle moves as normal, but the friction from this disc / plate arrangement tries to spin both tires at the same time. When you go around a corner the friction of the disc and plate are overcome by teh friction of the tires. I hope this helps, I could describe much better with pictures.
Jason
« Reply #2 on: January 26, 2007 - 10:11:24 AM »
Sorry I will restate the question...What is the difference betwen the "normal" rear end and dana or posi rear end?
Thanks for your reply...
« Reply #3 on: January 26, 2007 - 04:27:44 PM »
By "normal", that would be an open rear end. A "limited slip" rear is when both tires spin at the same time. The "Dana" would be the same, but it's much more beefier, and desireable if you plan on pounding on your car. The downside of the Dana is the price, once you find one.  :scared:
« Reply #4 on: January 27, 2007 - 02:47:08 AM »
 :2thumbs: I understand now. Dana is a posi(traction) rear end! I am really a  :newbie:  :-[
Btw...What do you have?
Offline cudabuyer
« Reply #5 on: January 27, 2007 - 05:35:47 AM »
ain't no questions dumb -  :burnout:
70 Dodge Challenger Convertible 6.1 Hemi
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #6 on: January 28, 2007 - 07:55:03 PM »
Are you sure you understand?  I think you are saying that a Dana "is" a posi rearend.  Am I right?
Because if I am, then you are misunderstanding what MEKrunner was saying.  A Dana rearend is the version of the rearend because of the manufacturer not because it is a posi.  It measures 9 3/4 inches on the ring (gear) in the Chrysler cars of the 60's/70's.  There are other Dana rearends that were used on makes and models of cars and trucks.  The Dana refered to in the Mopar cars is called a "Dana 60".  The Dana came with a suregrip (posi) unit installed.
I hope this helps.
Alaskan_TA
« Reply #7 on: January 28, 2007 - 09:40:01 PM »
Dana is the brand name. 40, 60 and so on is the series.
The brand name for the 8 3/4" rear is Hotchkis, but I am not certain on the spelling.....
Barry
« Reply #8 on: January 30, 2007 - 10:28:07 AM »
I hope this helps.
Yes, yes...Dana is one brand of positraction rearends  :thumbsup:. I know it is one brand of differentials but I didn't know how does it work..what kind of differential is it?...well now I know. Thank you anyway for a great post! :worshippy
One more question...Do all 'cudas have suregrip(positraction) rearend? :clueless:
« Reply #9 on: January 30, 2007 - 10:34:15 AM »
no most Cudas has the sure grip as an option you had to add
« Reply #10 on: January 30, 2007 - 10:39:01 AM »
So this means that you can only do one wheel burnout :dunno: Well these days almost all cudas have  sure grip differentials... :burnout:
« Reply #11 on: January 30, 2007 - 03:29:38 PM »
We like to call it one wheel drive.  :lol: Yes, that is how most of them came from the factory(open rear end). I have the sure-grip, but given my car was a base model, I'm sure that was put on later in it's life. I'm NOT complaining though.    :burnout:
Offline 360 'CUDA
« Reply #12 on: January 30, 2007 - 04:04:48 PM »
It's really funny when you see all of these 4wd trucks driving around. Most of them are 2wd with one drive wheel in the front and one in the back  :grinno:
Offline 6packCuda
« Reply #13 on: January 30, 2007 - 04:41:19 PM »
[/quote]
Yep, I've got one of those pickups.
Offline 360 'CUDA
« Reply #14 on: January 31, 2007 - 08:52:00 AM »
My Ramcharger was like that   :dunno:
