Author Topic: 340 block widths  (Read 1086 times)
Offline shatar4
  • 71 Challenger
340 block widths
« on: January 26, 2007 - 04:17:39 PM »
I am going to pick up a 340 tomorrow and wanted to build a frame of wood for it to sit on for the 5 hr drive home. What I need is the dimensions of the block where the ears are for the motor mounts and the dimensions for the back so it will not move around. If anyone has any other helpful hints on how to transport a motor, let me know. Thanks
1971 Triple black 340 Challenger
Offline Oldschool
  • Member Since 9-05-06
Re: 340 block widths
« Reply #1 on: January 26, 2007 - 04:33:33 PM »
Back in the day, we used to sit the motor inside a couple of old tires and then use tie downs and 4 corner it.  Worked pretty good---never lost one anyways........       :ylsuper:    :icon16:   :smokin:
Ken  --  In Georgia
Alaskan_TA
« Reply #2 on: January 26, 2007 - 04:41:37 PM »
These may help;
Alaskan_TA
« Reply #3 on: January 26, 2007 - 04:45:44 PM »
The sides are 2x8, the box ends are 2x4. There is a piece of 1/2 plywood nailed to the bottom to hold it together, and 3/4" plywood gussets nailed to each end.
Once you get it home you can add small caster wheels at each corner to move it around in your garage.  ;)
Offline shatar4
  • 71 Challenger
« Reply #4 on: January 26, 2007 - 04:47:53 PM »
Thats perfect!. Exactly what I was looking for. Thanks Alaskan_TA! What are the width sizes at each end?
« Last Edit: January 26, 2007 - 04:51:28 PM by shatar4 »
Alaskan_TA
« Reply #5 on: January 26, 2007 - 05:06:30 PM »
11 3/8" outside to outside;
Offline shatar4
  • 71 Challenger
« Reply #6 on: January 26, 2007 - 05:33:40 PM »
Thanks again, Your a life saver!
