Author Topic: Electric Fans  (Read 1790 times)
Offline 1970hemicuda
Electric Fans
« on: January 28, 2007 - 10:35:17 AM »
One of the blades on my original factory fan broke off last summer while driving, and by the grace of Father Mopar went straight down instead of up through the shaker hood.  I repalced it with an electric set up from Flex-a-lite and then it ran hot when the weather got above about 85 degrees.  Anybody had a similar problem ... then a solution?
Thanks
Re: Electric Fans
« Reply #1 on: January 28, 2007 - 05:21:23 PM »
I would go back to a factory clutch fan , they are far more efiicient than the electric fans
Re: Electric Fans
« Reply #2 on: January 28, 2007 - 08:10:55 PM »
The reason I didn't is because I heard they will throw a blade at high RPM's ... like 6000 +.  Any thoughts?
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Electric Fans
« Reply #3 on: January 28, 2007 - 09:28:18 PM »
I would have to agree with Chryco Psycho.
I did a bunch of reasearch on this topic when I was thinking about an electric on my Challenger.  After a bunch of reading and finding other people's experiences, I determined that unless you are willing to have a hot running car in the summer time, then you need to stick with a mechanical fan.
Needless to say I went with the clutch type fan.
Re: Electric Fans
« Reply #4 on: January 28, 2007 - 10:06:27 PM »
a properly working clutch fan will noty hit 6000 rpm , it should slip & run slower
Re: Electric Fans
« Reply #5 on: January 29, 2007 - 05:04:44 PM »
Ahhhh ... a clutch fan.  Now that makes sense.  :banghead:   I didn't think mine came with one originally.  That's a no-brainer then ... thanks!
