Thanks for crunchin the #'s, problem is the car was cloned into a cuda, it was a 318 auto car, No air, now has a 360 - 727 355 gears, the motor & trans were worked, I don't have any information on wether or not he changed the rad, it had one of those aftermarket shrouds, just a chrome piece of sheet metal bolted right through the rad core with those plastic bolts.
From hunting around a while, the 2998328 shroud seems to be the one that will fit the setup(well now maybe excluding the aftermarket fan?) I'll look for more #'s tomorrow afternoon, it does have the trans cooler in the bottom tank if that helps. Rich.
PS, i have the arm rests all boxed up, do you want me to send em out, I was thinkin a value of 20 & then try the gift thing, this way if they don't accept that the fees shouldn't be too high? Rich.
