You can get the material from Legendary but I agree with SilverChally, You would probably be better off buying the panels already done from them I've tried both ways, and gluing your own material on the panels is a real PITA! One problem I ran into was finding a glue that would hold in the heat, these cars get real hot inside when setting with the windows closed during the summer and the glue would soften and let the material come loose. If you do decide to do it yourself, the only glue I found that will hold is 3M Super Trim Adhesive in the spray can. Make sure it is the SUPER, as there is a regular trim adhesive, and it won't hold.
