Author Topic: 1972 dodge Challenger Broadcast Sheet Questions  (Read 3166 times)
Offline TreeFrog
    • TreeFrog
« on: January 29, 2007 - 01:39:33 PM »
I would like help decoding some info on the Broadcast sheet...if anyone can help, or knows wher I can look up the info.
Thanx up front ...
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline TreeFrog
    • TreeFrog
Re: 1972 dodge Challenger Broadcast Sheet Questions
« Reply #1 on: January 29, 2007 - 01:44:06 PM »
 :working:
1 Basic info is pretty clear
2 car: ENG: 44, D/Trans 34, D/Axel 51, D-8/Size 3, TUW/Tires T22, Trim Code B6 X9, Paint Style V01, Paint Style FY1 (Top Bannana), Roof Pnt/Style Top V1x Stripe 1st V7X
will continue as I have time...of to see the doctor
 :working:
Offline TreeFrog
    • TreeFrog
« Reply #2 on: January 30, 2007 - 12:15:19 PM »
3 Steering column 255X97005, Steering Wheell 19/X9, Horn Pad 64/X9, Rad 31, Inlet hose 15, alt 04, fan 34, fan/spa 36, bat 51,
Build
4 vac/fit 27, engine 661, carb 08, trans 873, pin 28, p/shaft 146, axle 101, Wheels: road 50, color TX? spare 00, wheel cover 60, frame 53, ft s/bar 00, shock ft 17, rr 11
OK I can only bring myself to do a little of this at a time... I don't expect all of this decoded, if you see anything of interest or anything that would be good to know...
Offline TreeFrog
    • TreeFrog
« Reply #3 on: January 31, 2007 - 06:54:56 AM »
CODES
5  TORSION BAR LT/775 RT/774, REAR SPRING LT/344 RT/344, CLUTCH/BRAKE PEDAL 3700, LABLES VEC/61 TIRE17, EXHAUST LT (THINK) 700 RT/269 TAIL PIPE LT/00, RT/66 CAR HEIGHT EP3, MAS CYL 31
6  TIME 1974, CARPET MAT FT/67 COLOR/X8 RR/7?, WIRING ENG FT 00 ENG RR/49 H/LP/43, PULLEY DRIVE/78 FAN/36, DRIVE BELT FAN/13 P/STG/84 A/C/00 A/INJ/00
Alaskan_TA
« Reply #4 on: February 01, 2007 - 06:12:35 PM »
You can find the 1972 sales codes at this link;
http://www.hamtramck-historical.com/images/dealerships/1972PlymouthOrderingInfo/1972_page_27.jpg
For the torsion bars, exhaust and so on, (the other two and three digit numbers on the sheet) they are the last two or three numbers of the actual part number or group assembly part number for things like the engine. To decipher those you would need a 1972 Parts Book.
T/Ake care,
Barry
