Author Topic: Questions on stock 440 exhaust manifolds  (Read 569 times)
Offline Grec
« on: January 31, 2007 - 07:46:12 AM »
My Challenger came to me with headers on it, but I am seriously thinking about going with a more factory-looking set-up.
Obviously the stock exhaust manifolds are much shorter than headers, so I'm assuming that there's an intermediate pipe that goes between the manifold and exhanst...?
Also, will exhaust manifolds from a '68-'69 440HP fit and be reasonably correct looking in an E-body?
Thanks.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: Questions on stock 440 exhaust manifolds
« Reply #1 on: January 31, 2007 - 11:24:07 AM »
yes the 69 manifold work , they are basically the same manifold , just the casting #s change & yes there is a head pipe between the manifolds & exhaust
Offline Grec
« Reply #2 on: January 31, 2007 - 11:26:34 AM »
Are those intermediate pipes easy to come by?
- 440 Six Pack
« Reply #3 on: January 31, 2007 - 11:28:01 AM »
depends what you want , most muller shops can bend a set for you OR TTi can supply what you need mandrel bent
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #4 on: January 31, 2007 - 11:38:08 AM »
I bought the pipes from TTI and they are great. I also have the 68-69 manifolds and the casting number is the only real difference.
1996 Dodge Viper GTS Coupe
