Yep, I can put it here too;
Barry Washington
Box 9632
Ketchikan, AK 99901-4632
Cars with 4-5 broadcast sheets seem to have two or three that match the car for the most part. The sheets in the bucket seats are the "wild cards". The reason is that once the order was filled in the trim shop they would slip the broadcast sheet inside the seat, put the plastic back on and it then went down a conveyor belt to the main assembly line.
Since the front seats were delivered to the main line with the backs on, there was no way to know if the sheet inside it matched the car it went into. The assembly line workers just grabbed the closest seat the right color and pattern and they bolted it in.
I have not heard of your R/T before, if you would like to register it you can print out the registry form at this link;
http://www.hamtramck-historical.com/register.shtml.....and then mail it in with the two sheets you found if you wish. If and when either sheet is claimed I will be sure to drop you a line and let you know also. I will also make sure that the car owners search their cars for a sheet for yours.
Thanks!
Barry
