Author Topic: Ok Power Brakes to Manual - Pushrod and Firewall question  (Read 1656 times)
Offline GoodysGotaCuda
« on: February 02, 2007 - 08:20:32 AM »
I've read here and there that there may be some sort of firewall plate/adapter needed when changing a power brake car to manual? Is this necessary? Anyone have a picture of what needs to change, if anything?
Also for those without a factory manual pushrod setup where is the cheapest/best fitting manual pushrod thats being sold?
Thanks!
-Mike :drunk:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: Ok Power Brakes to Manual - Pushrod and Firewall question
« Reply #1 on: February 02, 2007 - 11:07:36 AM »
yup it looks like this
« Reply #2 on: February 02, 2007 - 11:16:52 AM »
Whats the purpose of it? Build up that area of firewall by the pedal for the increased load on it?
It's mounted from the interior side of the firewall i assume, and not under the hood?
Anyone repop them, or you gotta find one?
And last, are they a/b/c/e/etc body specific or just any manual mopar will have one?
Thanks  :bigsmile:
1976 Dodge Warlock
« Reply #3 on: February 02, 2007 - 11:22:35 AM »
firewall side , B body 71-74 & E body 70-74
 I am not aware of a repro piece
« Reply #4 on: February 02, 2007 - 11:46:56 AM »
Thanks,  :bigsmile:. Any experience with aftermarket manual pushrods?
1976 Dodge Warlock
« Reply #5 on: February 02, 2007 - 08:10:14 PM »
not so far
« Reply #6 on: February 03, 2007 - 04:28:22 PM »
Thanks for the help Chryco, looks like a friend of mine out in Texas has a manual brake challenger he wants to make a power brake car. We'll likely just trade my booster/linkage/pushrod for his Firewall plate and pushrod.  :bigsmile:...not to mention he is the guy with the 833od I'm getting too.  :dogpile:
I'll have to see if the stock manual pushrod will work with the late model alum master.  :clueless:
« Last Edit: February 03, 2007 - 04:38:55 PM by Goody »
1976 Dodge Warlock
« Reply #7 on: February 03, 2007 - 06:58:37 PM »
it should
« Reply #8 on: February 13, 2007 - 01:12:56 PM »
Alrighty here is what I've aquired so far. Just waiting on the little foam gaskets.
  • Late model 1.125" Bore Alum Master Cylinder
  • AR Late model master adapter
  • Factory Dustboot
  • Firewall plate off a 71 Manual Brake Challenger
  • Manual Pushrod from same 71 Challenger
I do also need the pushrod retaining grommet.  :drunk:
Hopefully it all works.  :bigsmile: (and the pushrod is the right size  :clueless:)
« Last Edit: February 13, 2007 - 01:17:29 PM by Goody »
1976 Dodge Warlock
Offline vinb
« Reply #9 on: February 13, 2007 - 05:54:01 PM »
Hey Goody, master cylinder looks ok, but I like the garage floor paint better.. Nice...
