Well, in order to get 660 hp, you will need at least 300cfm from the. And you'll have to rev it a bit. You can get 280ish fairly easy. Beyond that, it takes a bit. I would suggest maybe some Indy iron -1s used if you can find some. The deal is, you're spending it either on new heads that can make the numbers, or iron heads that have to be prepped so much to make that number that they will cost close to the new. You either have it to spend..Or you dont. If you dont, you wont get there. It's that simple really. Personally, I'd get a set of RPMs and pay somebody a few hundred to mildly port them. They will easily make 290-300cfm at that point.
