i know most of us have gone through this choice. Well im there now which conversion kit is the best for the cash? I dont need a huge 4 piston kit or anything cause im gonna keep the 15's. But i wanna keep my wallet fat. I like the brakes on my T/A so i figure a factory size/style should be just fine for the cuda. Ive been looking at some used parts floating around on ebay but their prices are insane. Anyone know a decent lower cost oem style kit out there? thanks
Have you checked any of the used parts places like Tonysparts.com or texasacres.com.
If you get some used spindles and the correct adapters, you can run the 11 -3/4 brake setup.
You need the caliper brackets and rotors for a '75 up cordoba. The spindle needs to come from a '73-'76 A-body with disc, you'll also need the upper control arms. This is why the mpbrakes.com kit cost so much. 73'- E-body stuff is the same in regards to spindle and upper control arm. (someone correct me if i'm wrong)
I did this swap on my A-body, well sorta, it was a '73 Drum brake car, so all i needed was the spindle, but the rest came from texasacres.com.
I hope this helps.
Jason
