Author Topic: Spark Plug Readings  (Read 670 times)
Offline vinb
Spark Plug Readings
« on: February 03, 2007 - 06:12:41 PM »
Chryco, Check out my plugs today, Do they look on the lean side or normal. 340 w/T-Q carb jetts are .095/.143. 1996 rod with orange chrysler box, RN-9-YC Champions, timing 34*. Approx. 2,700 miles on them. The car all of a sudden is just burning my eyes today. No miss firing , I also leak tested the engine, I went from 5% average back in May of this year to average 23% today..Don't know why yet....Vin...
Offline vinb
Re: Spark Plug Readings
« Reply #1 on: February 03, 2007 - 06:13:32 PM »
Sorry Plug photo..
« Reply #2 on: February 03, 2007 - 07:02:05 PM »
they look lean to me , the heat range of the plug May have something to od with the color but I would jet up
Offline vinb
« Reply #3 on: February 03, 2007 - 07:13:07 PM »
Thanks CP, I was going to try 2 heat ranges hotter to RN-11-YC anyway. But the jetting I could go to a .098 primary and a .157 in the back, but that seens a l;ttle rich to me for a street engine. I was just thinking if it was something oin the heads. i was told that two different machine shops had there hands on these things, so I was going to have another pair of 587's done since there on the shelf taking up space. Also the leakage concerns me a little too...         I re-rung the engine back in April of this year.....
« Reply #4 on: February 03, 2007 - 07:25:06 PM »
they are not way off , they do have some color , but to be safe & try for at least a light tan color
Plug reading is not the best way to dial it in anyway , I have tested on a dyno & plugs that looked lean seemed rich in a few cases & the other way too , rich looking plugs showed lean
Offline vinb
« Reply #5 on: February 03, 2007 - 07:32:32 PM »
I'll mess with the jetting tomorrow and try a couple of things, Thanks CP.....
« Reply #6 on: February 03, 2007 - 07:35:14 PM »
no prob, if it i s lean you should feel a power difference as you richen it
