Author Topic: SIZE Matters  (Read 1281 times)
Offline cudabuyer
SIZE Matters
« on: February 04, 2007 - 05:30:16 AM »
Okay so now the resto mod 70 challenger has 11.75 Wilwood disc brakes all around
stock wheels obviously do not fit
I assume the collapsible wheel in the trunk is not an option
I was told maybe other collapsible / blow up wheels may fit ??
What have other members done since converting to bigger brakes and aftermarket wheels - have 18 billet specialities wheels now
Thanx
70 Dodge Challenger Convertible 6.1 Hemi
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
Re: SIZE Matters
« Reply #1 on: February 04, 2007 - 08:29:37 AM »
I assume that you tet fit a 15" wheel.  Is it the caliper that is causing the problems?  How about a 16" wheel for a spare?  I know that it is kinda large, but it may be more managable than an 18" spare.
{oo/===\oo}
Re: SIZE Matters
« Reply #2 on: February 04, 2007 - 09:55:10 AM »
Have you tried a space saver from a Caravan or Mustang... lug pattern works .
Offline 71340RT
Re: SIZE Matters
« Reply #3 on: February 04, 2007 - 10:12:19 AM »
What years of Caravan and Mustang space saver tires fit?
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Re: SIZE Matters
« Reply #4 on: February 04, 2007 - 10:59:42 AM »
I have a 98 Caravan & 98 Mustang. Both have the 4.5" bolt pattern but should be the same for all 5 lug caravans,voyagers,town& country & 94-2007 mustangs(hub size could be an issue).  There could be backspacing issues but as narrow as the spacesaver spares are I would think it might just work. I can take measurements if you want.
Offline Hopalong
Re: SIZE Matters
« Reply #5 on: February 04, 2007 - 02:02:25 PM »
The early minivans had 5 x 100 mm (4") so make sure yu know what you've got before you pay for it.
{oo/===\oo}
Offline cudabuyer
Re: SIZE Matters
« Reply #6 on: February 05, 2007 - 08:09:14 AM »
great info so far, yes the calipers come in contact with stock rim spares,
i was told that the mustang may fit as I want to customize the trunk, put the air ride compressor system in the trunk for the air bag suspension & still have room for the golf clubs (just joking)
need room for small bags for the power tour
