Author Topic: Clutch size question  (Read 7315 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
Re: Clutch size question
« Reply #15 on: February 27, 2007 - 07:59:39 PM »
Hello Folks,
Just read this post.  I'm curious how this issue turned out (with the spring and all).  I am in the process of building a 600HP small block (414 cid) for my '70 Challenger convertible.  It has a 23 spline A-833 with 3.55 gears in the 8.75 rear end.  I will be having someone check out the gear ratios in the tranny this week as this was installed by the previous owner nearly 6 years ago.  All I've been told is that they decided on a lower first gear when they built the car.  Anyway, getting back to the clutch.  I found it interesting to read about clutch sizing and A-833 spline differences (I'm hoping my 23 spline will handle the 600HP OK).  But most interesting is the discussion regarding the "over-center" spring.  I will be running a McLeod Street Twin (diaphragm) clutch.  Gene (at McLeod) said I should remove the over-center spring with this application.  When I called McLeod today to confirm these instructions, the gentlemen I spoke with said the same thing, but also said to keep the pedal return spring installed.  I told him it was an "E" body car (1970 Challenger), but I don't believe I know about this spring.  I don't see any reference to it in any af my books including my service manual.  The car was equipped with the old Keisler Hydraulic T/O kit from 6 years ago.  So, I don't know what the previous owner did with all the springs and linkages when that was installed.  I have decided to discard the hydraulic set-up (it's just too finicky) and go back to the stock Z-bar set-up.  I was curious as to whether or not I needed to purchase an over-center spring (now I know I don't have to).  I am in the process of ordering all the necessary parts for the stock set-up (going with Brewer's Performance for this; if any suggestions on someone better, please let me know).  So, is there a 'pedal return spring' and if so, where does it go?  Thanx
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline AMXguy
« Reply #16 on: February 27, 2007 - 08:24:13 PM »
 The only spring you'll have or need is the one on the fork. the new CF Dual Friction I just put in had a full page orange notice in the box saying to remove your overcenter spring.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline filmsurgeon
« Reply #17 on: February 27, 2007 - 11:15:00 PM »
Thanx AMXguy.  Anyone have any idea why the guy at McLeod spoke of a "pedal return" spring?  Help with the other planned set-up stats would be greatly appreciated.
« Reply #18 on: February 27, 2007 - 11:56:59 PM »
The overcenter spring does both , it returns the pedal to the top & keeps any pressure from riding on the throwout brg & helps pull the pedal down when you push on it
Offline Killer_Mopar
« Reply #19 on: March 07, 2007 - 11:59:43 PM »
Well I took that biga$$ spring out and all I can say is :woo:. The pedal feels 100 times better. I cant wait to drive it to see if that was definitely the problem, but so far Im thinking it was. Thank you very much for the help :worshippy
Thats very interesting. I wonder if that piece of paper is a recent addition to the instructions or if they just forgot to package it with the clutch I bought :pullinghair:
