Author Topic: 72 challenger Drum/Disk  (Read 786 times)
Offline TreeFrog
    • TreeFrog
« on: February 05, 2007 - 07:37:46 AM »
my 72 Challenger has drums up front.  I would like disks...does any other car interchange with the Challener?
I may have access to a 78 or 79 Volare with front disks...any chance?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline GoodysGotaCuda
Re: 72 challenger Drum/Disk
« Reply #1 on: February 05, 2007 - 07:46:45 AM »
You could also do the junkyard upgrade which is pulling the 11 3/4" Brake setup off a late b-body. The b-body spindles will bolt right up to a stock ebody. (however some say due to they are a little taller than stock it throws the ball joint at an weird angle. I will be running them with HD Moog upper ball joints.  :dunno:). Another option is the late Abody 73-76 disc spindles will bolt right on a ebody, stock height and accept the 11 3/4" rotors. You will need the 11 3/4" caliper adapters, dust sheilds and rotors to put them onto the abody spindles.
I'm doing junkyard late cordoba spindles, new 11 3/4" rotors, reman slider calipers, new lines hard/flex here pretty soon, replacing my stock disc stuff.
http://www.moparaction.com/Tech/archive/disc-main.html
1976 Dodge Warlock
Wheel & Tire Specs:Link
