Author Topic: Valve cover PCV  (Read 636 times)
nivvy
Valve cover PCV
« on: February 05, 2007 - 10:01:26 AM »
Do you really need an extra hole in the valve cover for a pcv if you already have a hole for a breather??
Re: Valve cover PCV
« Reply #1 on: February 05, 2007 - 10:26:28 AM »
The PCV valve should be on the opposite side cover from the breather. If your covers have a hole for a breather on each side, you can buy a grommet to get the PCV valve to fit it... if that's what you are asking.
Re: Valve cover PCV
« Reply #2 on: February 05, 2007 - 12:57:26 PM »
you can use the Ford style fill cap with the PCV in the removable fill cap
nivvy
Re: Valve cover PCV
« Reply #3 on: February 05, 2007 - 01:29:13 PM »
These new valve covers im gonna buy are fabricated and only have 1 hole on each valve cover.....1 for oil fill and 1 for a breather...
Re: Valve cover PCV
« Reply #4 on: February 05, 2007 - 03:59:25 PM »
OK,
  Sounds like mine.  :grinyes: I have the PCV valve in one side, the breather, in the other. I just pull the breather out at oil change time. This is not how my engine bay looks now, but I still have the same covers. Notice the grommet on the passenger's side.
