1970 AAR and T/A Power Steering Pump Unit, complete
Author Topic: 1970 AAR and T/A Power Steering Pump Unit, complete  (Read 3014 times)
Offline bluedodgehemi57
« on: February 07, 2007 - 07:37:17 PM »
1970 AAR Power Steering Pump
This is an original power steering pump, complete with the pulley, mounting brackets, fluid cooler and associated hoses.  This was rescued from a very wasted 1970 Plymouth Cuda AAR.  The Part Number is 3004800, and it would presumably also be date correct for a 1970 Dodge Challenger T/A.
The pump is a 1.06ci displacement unit (3/8 inch treaded hole shaft) that was specifically matched to the quick-ratio (approx. 2.5 turn) gearbox found on the AARs and T/As.  The pulley is slotted and around 7 inches in diameter, compared with stock pulleys that look to be around 5 inches.  As noted, this also includes the finned power steering fluid cooler.
My Chrysler Parts Interchange Manual also indicates this part-numbered pump will also work on the:
•   1969 Belvedere, Charger and Coronet with V8
•   1969 Fury, Polara with 6cyl or V8
•   1970-1971 Charger, Coronet, Duster, Satellite and Valiant w/318 or 340
•   1972 Dart, Duster, Valiant, Charger, Coronet and Satellite w/V8
•   1973-1974 Dart, Duster and Valiant, all engines
•   1973 Barracuda, Challenger w/V8
Please call me at: (949) 903-6678 or email at: bluedodgehemi57@yahoo.com with a realistic offer.  This part will be going on Ebay very soon, so if you want an original power steering pump unit for your AAR or T/A, let’s talk soon.
Will have pictures very soon.
