I might be giving my 360 engine to my father if he keeps having problems.
Well my 360 was balanced using the B&M flexplate, so I did not have weights on the torque converter. My father has the 360 flywheel on his motor.
Is there a way to take my flexplate and have the flywheel drilled out to match, so the motor will not be unbalanced, or would you think the flywheel would be close enough to just put on and run?
