Author Topic: Small Block VS. Big Block  (Read 16137 times)
nivvy
« on: February 10, 2007 - 05:32:23 PM »
I know that Big Blocks bring more value to your car but as far as performance builds... man some of those seriously big stroked small blocks make huge power!!! The 2006 Pump gas drags naturally aspirated small block class were a little faster than the naturally aspirated big block class !!! with less cubes!!!
Offline 360 'CUDA
Re: Small Block VS. Big Block
« Reply #1 on: February 10, 2007 - 05:58:02 PM »
I like small blocks but the fastest my Valiant went was only 10:62 so maybe I did it wrong  :dunno:
Offline Carlwalski
« Reply #2 on: February 10, 2007 - 05:59:29 PM »
So I guess there's no question so is it statement?  :dunno: I like both and am lucky enough to have both.
The 340ci is not stock around the 400hp mark once we are done....and man it pulls hard and sounds super crisp.
The 'Cuda will be my drivers car where-as the Challenger is more my cruiser and is better suited to highway brawls over stop light action. Though, it's built stock and to be more of a cruiser....still lights them up with ease though.  :naughty:
 :2cents: :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 71340RT
« Reply #3 on: February 10, 2007 - 06:11:56 PM »
A small block built right is more than a hand full. I like the big block torque but I'll have to say I've seen some small blocks that can more than handle there own on the street or at the drag strip.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
« Reply #4 on: February 10, 2007 - 10:13:24 PM »
I prefer the big block from a design standpoint
Offline Cuda Cody
  • Vancouver, WA
« Reply #5 on: February 10, 2007 - 11:03:20 PM »
Big Block = Big torque.... At low RPMs!
Offline asm74
« Reply #6 on: February 11, 2007 - 12:13:17 AM »
Can you elaborate?  what are the critical design differences between a big block and small block?  I'm really asking this, i have no experience with big block mopars...
73 Challenger
« Reply #7 on: February 11, 2007 - 05:16:12 AM »
I don't what exactly Chryco means by that, but for one, the intake design on the big-blocks is better. Rather than relying on the coolant flow to cool it, it is raised up to allow air-flow to keep it cool underneath. The purpose of keeping the intake cool, is so the carb. doesn't get hot. A hot carb. can have vapor lock issues.
« Last Edit: February 11, 2007 - 05:27:40 AM by MEKrunner »
« Reply #8 on: February 11, 2007 - 05:27:51 AM »
For starters
small block has less head clamping ...10 bolts as big block 17
water ports in the intake on sm blk
intakes are easier to change on a big block
water pumps easier to change on a big block
easier to do timing chains on big blocks
oil pumps easier to change on big block
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
« Reply #9 on: February 11, 2007 - 06:45:24 AM »
Don't forget the goofy lifter angle (59*) of the small block.
{oo/===\oo}
Offline Plum6Pak
  • Plum6Pak
« Reply #10 on: February 11, 2007 - 06:47:36 AM »
I like both but if faced with a decision and had a choice I'd go big block for sure. You can build anything to beat just about anything else with enough money but bang for the buck, the big block already has the torque and more potential for the same money spent. Now I wouldn't go pull out an original 340 out of a Cuda or Challenger and drop in a big block but if building up a non numbers car I'd go big block hands down. But, I may be just a tiny bit bias.  :grinyes:
Offline IMNCARN82
  • LeDZeP
« Reply #11 on: February 11, 2007 - 06:53:36 AM »
I've had both. A 340 and a 440. Neither were stock. I have to admit this 340 can be quite a handfull :burnout: especially with a 4 speed. :cooldancing:     All in all......the 340 Rocks!      People see the hood badges and underestimate.  But I'm usually gone by then...
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #12 on: February 11, 2007 - 07:00:28 AM »
 :iagree: But I've never owned a 340, and I understand the earlier years were a much better motor? Which I don't fully understand unless it deals with the mid to late 70's emmsions requirements, but who is going to build one back to stock or totally factory correct for a street car today?
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline Mr. 440SixPack
« Reply #13 on: February 11, 2007 - 07:36:11 AM »
Hmmm... I will use this topic to ask a question... Lets say we have two cars, both have same transmission, same rear end, same tires but one car has stock 340+6 pack engine and the other one has stock 440+6 pack. Which car would win a 1/4 mile and 1/8 drag race. :clueless:
My dream: 1970 Plymouth 'Cuda 440+6 Pack/4 speed Pistol Grip/Dana 60 rearend/PS, PB/Lime Light/Shaker hood/Rallye dash...
Offline IMNCARN82
  • LeDZeP
« Reply #14 on: February 11, 2007 - 07:39:58 AM »
 :popcorn:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
