Author Topic: Small Block VS. Big Block  (Read 16141 times)
Offline Plum6Pak
  • Plum6Pak
Re: Small Block VS. Big Block
« Reply #75 on: February 24, 2007 - 07:05:59 PM »
Dang Plum! You been reading your wife's romance novels again :dunno: :biggrin:
 :roflsmiley:  Nope, when you get to be my age and with all that's going on around my place all the time, I still need to get my thrills somehow and that little story is as close to........uh, well, without actually getting uh, hmm, ah shucks, you know what I mean. And just so I don't get into trouble here, I won't mention what I'm running, small block, big block (in my dreams) or a stroker in that department.   :22yikes:  :2thumbs:
nivvy
« Reply #76 on: February 26, 2007 - 05:22:05 PM »
http://promaxcarbs.bizland.com/Engines.chtml
same price for small block as big block but small block makes 75 more HP ....  :burnout:
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #77 on: February 27, 2007 - 09:02:32 PM »
Mopar rule of thumb:
A small block weighs 100lbs less than a big block, a big block weighs 100lbs less than a Hemi.
100lbs cost around 10hp in hp-to-weight ratio. 100lbs is 0.10 seconds at the track.
So, bugger all difference. 10hp loss when you're making 80hp+ more in stock form.  :thumbsup:
I'm wondering if the weight difference isn't a little greater than 100 lbs....
 http://sydnet.net/dodge/prislista%20challenger%2070/ph26.htm
R/T (big block) weighs 370 lbs more than a small block V8 Challenger.
I'm sure this includes the other beefier components.
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline Carlwalski
« Reply #78 on: February 27, 2007 - 09:08:15 PM »
Not sure, I got this from either Foose team or some other car builders.
They said it's the basic rule of thumb, always has been, always will be. Perhaps not 318s?  :dunno:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
