Author Topic: Fabricated Intakes  (Read 789 times)
nivvy
Fabricated Intakes
« on: February 11, 2007 - 07:36:59 AM »
I love the look of fabricated valve covers but do the fabricated intakes serve ant purpose other than looks...??they dont look hard to make at all and I have a metal shop 3 blocks from my house...
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Fabricated Intakes
« Reply #1 on: February 11, 2007 - 12:08:37 PM »
 :popcorn:
Offline 70B@rracuda
« Reply #2 on: February 11, 2007 - 12:57:51 PM »
I dunno, but that small block looks mighty spendy.
« Reply #3 on: February 11, 2007 - 02:03:36 PM »
I'm sure that type of intake has it's purpose. Being so tall, I'm guessing it's made for top end horsepower. My question is, can that possibly fit under any hood, or is this for a car that goes without one?  :dunno:
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
« Reply #4 on: February 11, 2007 - 04:58:53 PM »
There is a lot more to them than looks.  The runners are designed to be a certain length for optimal rpm.  They are usually made of aluminum, not the easiest material to work with, requires tig welding.  The runners also usually taper as they go into the head port.  The plenum is designed to a certain size for the application.  Lotsa work and big bucks.  If you are not building an all out race car, then you don't need one.  You could use one, but it probably will not work the best on most street cars.
{oo/===\oo}
Offline moper
« Reply #5 on: February 11, 2007 - 07:46:05 PM »
The welding and fit is the least of it...lol. Those intakes use soem big science. You cannot duplicate one. I'm not saying one you weld up wouldnt run. But they aint justfor looks...
« Reply #6 on: February 15, 2007 - 09:23:22 AM »
There is a lot of research that goes into the fabricated intakes. Things like runner length, runner volume, port configuration, primary and secondary wave tuning, air flow tuning, fuel flow tuning, plenum volume, carb configuration and layout, boundery layer friction and probably a few other things all figure into their design. An added benefit is also maintaining a cooler charge as well. Running air and fuel through the runners cools sheet aluminum a heck of a lot fasater than it can cool a chunk of cast aluminum. These intakes are thoroughbred race pieces. With price tags around $5000, I can't imagine there are many of us willing to run one on the street.
