Author Topic: Another clutch question  (Read 804 times)
Offline 71chmark
« on: February 12, 2007 - 04:42:56 PM »
Twelve years ago I bought an 11 inch clutch and a 10.5 inch pressure plate (from Hays) that was sized to accept the 11 inch clutch meaning I didn't have to change the flywheel or bellhousing.  I didn't even have to align the disc due to the tight clearance.  Is the 10.95 and 11 the same?  I need to replace my disc because it became impregnated with oil from a  leak but the pressure plate is still good with maybe 100 miles on it.  I'm not sure what to get.   I have the 18 spline.
I may be schizophrenic,
Re: Another clutch question
« Reply #1 on: February 12, 2007 - 04:59:24 PM »
the 11" disc is the same for the 11" 143 tooth & the 10.95" 130 tooth ,McLeod part# is 260851 for the 18 spline
Offline 71chmark
« Reply #2 on: February 12, 2007 - 05:42:15 PM »
Thanks and that's what I'll get.
« Reply #3 on: February 12, 2007 - 05:52:38 PM »
 :2thumbs:
