Author Topic: Which Drivetrain do you like?  (Read 1820 times)
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« on: February 13, 2007 - 12:40:20 AM »
Well, it looks like I might be giving my Challenger's 360 motor to my father to put in his Dart, so I was wondering if I could get everyone's opinion on my two ideas for the new drivetrain.
Option 1: Build a cast crank 440 with a mild cam, ported iron closed chamber heads, 9:1 to 10:1 compression, 727 with 2000 RPM converter, and 3.23 suregrip.
Info on build
- We already have the engine/tranny but needs rebuilding.
- We have the iron heads, but there is a small crack under the valve cover over one of the water ports.  Is there a good way to weld these?
- Already have the 3.23 gearset
Option 2: Build a budget 408 (360 stroker) with cast crank and stock rods, torquey cam, iron heads, 9:1 compression, A500 with 2000+ stall lockup converter, and a 3.91 or 4.10 suregrip.
Info on build
- We have a spare 360 block.
- Have an A500 in the garage, needs rebuilding.
Well this is a hard decision for me because I would love to have either setup.  The ony problem is that this will be done on a limited budget, about $2000.  I know that is not much, but that is all I can spare at this time, and I do not want the Challenger to be sitting for a long time waiting for parts.
So give me your opinions/ideas on my setup.
Thanks in advance.
Offline Carlwalski
Re: Which Drivetrain do you like?
« Reply #1 on: February 13, 2007 - 12:51:36 AM »
I voted 440/727, maybe I'm a little biased maybe I'm not. Could it be possible to find a A518 and run 4:10s with the 440? With 3.23 gears it will be nice but with 4.10s it will be NICE. It was a close call and I can see why you'd want some opinions. The stroker 408ci sounds yum too, good gears, OD, less weight.
Tough call, good luck with your decision.  :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Jacksboys
« Reply #2 on: February 13, 2007 - 12:59:00 AM »
I forgot to mention that I will have to get another exhaust if I go the 440 route.  That will also use some of the 440 budget.
Decisions, decisions  :pullinghair:
Offline Jacksboys
« Reply #3 on: February 13, 2007 - 01:01:10 AM »
It is possible, but I am hoping to keep the cost low and use the existing parts that I have.
Offline Carlwalski
« Reply #4 on: February 13, 2007 - 01:24:22 AM »
In that case, I'd go for the 360-408 stroker route. Better gears, good hp and OD.
What are you intentions of the car? Cruiser, street/strip, both? :dunno:
Offline Jacksboys
« Reply #5 on: February 13, 2007 - 01:45:01 AM »
It will mainly be a cruiser, but on a rare occasion it might see the strip.  I have never taken it to the strip, but it would be nice to just see what it would do.
I figured the 408 would be the most economical, but the 440 would get more respect.    :pullinghair:
Offline 71bigblock
    • Steve's Mopars
« Reply #6 on: February 13, 2007 - 11:17:06 AM »
I would definitely go with the stroker.  But can you do that for less than 2k?    :dunno:
nivvy
« Reply #7 on: February 13, 2007 - 11:41:21 AM »
I dont see how you can build a 408 stroker for $2000 .... I say save up a little more cash...why hurry its crappy out.... just my  :2cents:
kudakidd
« Reply #8 on: February 13, 2007 - 12:23:32 PM »
ain't no replacement for displacement. 440 baby!
Offline Jacksboys
« Reply #9 on: February 13, 2007 - 01:23:17 PM »
I can get a cast eagle crank for $240, then use stock rods, and new pistons (not sure on price yet).  Have it balanced for $200. Maybe $1000 or less.
etc, etc
Already have a carb, decent '974 heads.
I think it is possible if I keep it economical and not try to make a race engine.
440 = Respect
Very true, but I like the idea of the overdrive.
Decisions  :pullinghair: :pullinghair:
Offline Carlwalski
« Reply #10 on: February 13, 2007 - 01:31:02 PM »
440 = Respect
I think you just made your decision mate, like I suggested, use the stroker money to buy a A518.
440ci with a OD Automatic, simple, plan solved. Respect, high gears and good cruising.
Especially if you going to stroke it "mildly" the 440 will probably make that mild stroker's hp in stock form.
:2thumbs:
Offline Jacksboys
« Reply #11 on: February 13, 2007 - 01:37:35 PM »
:2thumbs:
Ok, if I go that route, I have to have one of the heads welded (to keep the cost down).  There is a small crack in a water port under the valve cover.  How hard is it to weld?
Offline Challenger6pak
« Reply #12 on: February 13, 2007 - 01:54:08 PM »
The only one that could answer that would be a good shop that can weld cast iron.  If the heads weren't ported I'd say replace it.  You may still have to go with a replacement and port it to match.
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #13 on: February 13, 2007 - 05:45:06 PM »
Rebuilds can be costly for sure, but if your changing you may as well go for the 440 / 727. Just save another 4K and build it wild and ready to scream. I expect to be a tad over 6K in the next 440 and it won't even be a 6pk, perhaps dual quad though, just a thought. Make a list of what/how you'd like to build it and then say get a summit book and add up your prices, then you also will know what you can change if neccessary. BTW, my list also had heads and tranny rebuild cost.
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline Street_Challenged73
« Reply #14 on: February 13, 2007 - 06:19:12 PM »
I voted for the stroker sb option, but I'm kind of biased to sb's. :-[ :biggrin:  If you could swing it, I'd say go for the 440/727 combo, but I think a stroker would be the recipe for some fun. (not to mention taking down many bb Chevy's and Fords while doing it.) :cheers: :grinyes:
