Author Topic: Real V Code 440-6 to Hemi Clone?  (Read 4654 times)
Offline Andrew
Re: Real V Code 440-6 to Hemi Clone?
« Reply #30 on: February 15, 2007 - 02:44:41 AM »
I would put a hemi in it, but not a 426. Get a 472(?) or 528 hemi.
As N9671x2 stated, changing a 440+6 car to a hemi car and back again is much easier than doing the same conversion on any other barracuda, and its not like he wont be able to switch it back again.
A member here had a V code '71 cuda with a hemi crate engine in it and a 5-spd, and i would probably prefer that car over any true hemi car.
nivvy
« Reply #31 on: February 15, 2007 - 02:45:28 AM »
I seen a car in the magazine with that and it actually came from the factory with a simulated vinyl roof....painted black ???
Dont understand about the missing numbers though....If that car really is what it looks to be I would definately have Galen Govier look at it...
Offline n9671x2
  • I love YaBB 1 Gold!
« Reply #32 on: February 15, 2007 - 06:00:31 AM »
I apologize for  :stirpot: on the fendertag and the vinyl top listed twice!!!   I don't think anything is black and white on these cars, especially from plant to plant.   It is rare, but these cars have slipped out without body stamps.   If yours is completely sandblasted, there won't be any speculation if they are filled in or welding done in these areas.   Aside from swapping motors, were you going to restore it back to original color etc..??
Offline moper
« Reply #33 on: February 15, 2007 - 09:31:12 AM »
Being that it's a '70, you may find a few things weird. Also, depending on it's history, the radiator support could have ben replaced the right way, making it almost impossible to tell it's not original to the car. You can't say "always" with Mopars, and 70 E bodies are even worse.
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #34 on: February 17, 2007 - 10:02:22 AM »
I can't see how installing a Hemi will hurt the value of the car. It can only make the value higher if the #'s drivetrain is also factored in.
You can't hurt it so enjoy it the way you want to.  If I saw it at a car show with a Hemi and checked the VIN# and saw it was a V code car, I would still think it miles ahead of 318 clone car values.
Why are the dash VIN rivets wrong though, has the pad been removed?? With no body numbers visible and wrong rivets holding the VIN tag to the dash pad I would be more than a little suspect that some trickery may be involved.
2013 Tige' RZR 343hp
Offline Cuda Cody
  • Vancouver, WA
« Reply #35 on: February 17, 2007 - 08:16:12 PM »
Dash VIN's rivits were Rosets not round.
Offline JS27N0B
« Reply #36 on: February 17, 2007 - 08:44:47 PM »
I know that....that's what was in my post.
Offline GreenFish
« Reply #37 on: February 19, 2007 - 10:39:16 AM »
I am going to have to agree with the masses here, If you want a hemi car i would either go buy a new one. Or sell the one you have and then buy a hemi car. Your 6 pack car is worth a lot of cash. More than what a hemi clone is worth and not much less than what a decent real hemi is worth. To bad you live so far outside the US, it would sell in no time here.
Offline Challenger6pak
« Reply #38 on: February 19, 2007 - 02:42:07 PM »
On the top of the cowl there are plastic vent screens.  With the passenger side vent screen removed use a mirror to look at the back side of the steel cowl that goes toward the outside of the car.  Look at the back side of the spot NZ pointed out where the number should be.  If you can't see there, feel the back part of the steel.  Are there any signs of repair or replacement of the metal.  When people delete old numbers they many times just weld them up, leaving the indentation on the back.  I have seen a smooth cowl that you could read the numbers from the back with a mirror.
As far as the car goes, I would leave it alone.
« Last Edit: February 19, 2007 - 02:45:47 PM by Challenger6pak »
