Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Someone Help me make my fuel guage work !
« previous
next »
Print
Pages:
1
2
3
4
Author
Topic: Someone Help me make my fuel guage work ! (Read 5860 times)
Devil
Sr. Member
Forward, Together Forward
Re: Someone Help me make my fuel guage work !
Reply #45 on:
February 20, 2007 - 10:01:07 PM »
DO YOU HAVE THE RIGHT GAUGE?!?!?!
Goody posted above the part numbers for the Phantom Autometer Chrysler gas gauge. If you don't have the right one, it will never work right.
Check here to see that you have the right gauge.
http://www.egauges.com/vdo_mult3.asp?Type=Fuel_Level&Series=Phantom
Ryan
Last Edit: February 20, 2007 - 10:10:18 PM by Devil
Logged
Ryan's Cars in Barns
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
73EStroker
Sr. Member
Reply #46 on:
February 20, 2007 - 10:34:50 PM »
Stroker - it sounds very much like the sender. Also make real sure the ground is absolutely perfect on to the frame for these tests. The slightest bit of resistance (read rust, crap etc) can cause a low current draw (such as a gas guage) to not work. You may have damaged the sender when installing it or you could have damaged the float which would make it sink and read way less when you put the fuel in the tank. Think of a small dinghy sinking - it just goes below the waterline and stays put.
Logged
Barry (Salmon Arm)
DAYLEY/CHALLENGER
Resident
Still My Inspiration..1971, Rockingham, Nc
Reply #47 on:
February 27, 2007 - 08:49:14 PM »
Just wanted to put my 2c in..........You have a sending unit that was originally set up with a 1/4" return line. This was used with the 440 and 426. What engine do you have? I purchased the correct ground strap and the pics show how I attached it. I haven't hooked my wiring back up yet so I don't know if mine even works. Good luck. David
Logged
Dave or David
nivvy
Guest
Reply #48 on:
February 28, 2007 - 01:11:06 PM »
here is a pic of my ohm meter....how do I set it to test sending unit???
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #49 on:
February 28, 2007 - 02:37:57 PM »
Your test leads should be in the center and right hole at the bottom. Also, the dial should be pointing at the "200" at the bottom. That is the 200 ohm range, meaning it will read anything less than that.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
nivvy
Guest
Reply #50 on:
March 06, 2007 - 03:45:29 PM »
well I got my new sending unit...hope it works...or
Logged
Jacksboys
Sr. Resident
Here Since 08/28/06 GEORGIA
Reply #51 on:
March 07, 2007 - 11:07:41 AM »
Good luck
Logged
1971 Dodge Challenger: 360/904/3.23
Print
Pages:
1
2
3
4
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
