Author Topic: Driveshaft Strength  (Read 1664 times)
nivvy
Driveshaft Strength
« on: February 15, 2007 - 06:15:53 AM »
Well about the only thing I havent changed yet for my 500 StRoKEr is the stock driveshaft and no I havent heated up the streetslicks yet and jumped on it...so my obvious question is the stock driveshaft strong enough....I dont think but what do you experts think?
If not what kind should I get ?? aluminum / chromoly steel etc???
Denny driveshafts say if you can break it theyll replace it...anyone deal with them?
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Driveshaft Strength
« Reply #1 on: February 15, 2007 - 10:29:11 AM »
 :popcorn:
Offline tactransman
« Reply #2 on: February 15, 2007 - 01:12:39 PM »
I say if you are running slicks, upgrade to aftermarket.  :burnout:
Terry-tactransman
Union, Mo.
Offline moper
« Reply #3 on: February 16, 2007 - 09:41:58 AM »
Denny's is very particular. They fit perfect as long as you measure right. I didnt like the fact they refused to sell me a replacement Ujoint for their shaft tho. (customer's car). They said they were having delivery issues because Spicer had just been sold, and they couldnt get the joints they were ordering, and they needed them for the driveshafts they had on order. I used a local replacement from a local driveshaft place. The local place will make the car's new driveshaft in a month or two. The Denny's one was spec'd too short. As far as stregth, depedning on your hook, you'll have a harder time with joints than the tubular shaft. I wouldnt get an aluminum one. With 3" exh and a big diameter shaft, things can get dicey under the car.
« Reply #4 on: February 16, 2007 - 02:05:09 PM »
Get the 7290 joints for sure [assuming your diff has the right yolks , trans slip yolk included ] aluminum is lighter & hits harder as it has no spring to it , steel has spring but weighs more , either will work
« Last Edit: February 17, 2007 - 12:59:11 PM by Chryco Psycho »
Offline oldkimmer
« Reply #5 on: February 17, 2007 - 11:14:44 AM »
DEFINATELY aftermarket, or u will get a lesson u dont want or need.........kim.
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
nivvy
« Reply #6 on: February 17, 2007 - 11:55:31 AM »
I have spicer 7290 u joints on the stock driveshaft now..
Offline CrazyPete
« Reply #7 on: February 17, 2007 - 04:48:35 PM »
what kind of hp are u thinking your gonna see? that would help me make a choice more than anything.
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
Offline Oldschool
  • Member Since 9-05-06
« Reply #8 on: February 17, 2007 - 04:52:08 PM »
I'm running a little over 800 HP with big a$$ slicks and a 727 auto.  Aluminum shaft with zero problems.......     :cooldancing:
Ken  --  In Georgia
