Author Topic: Yes another Clutch Question!!!  (Read 1243 times)
Offline gichy
« on: February 16, 2007 - 06:18:07 AM »
Just like everyone else there is way too many Clutch choice's
I am trying to figure out which clutch to buy and what size to buy.
The Flywheel (130 tooth) is from a 318 3spd original motor and trans
The old clutch is a 3 finger 10.5"
Now I have a 340cid 450hp with a A833 OD
Since reading all the info on this site about Mcleod Clutch's, I will most likely be buying one.
Now Which One / Size
Mcleod Web site:
        Disc               P/P               Disc               P/P              T/O
340" 5.6L ENG. 1973-68     B&B     10.5" [4]     1X23     260121     360156     260821     360153     16053
RECOMMENDED                     DIAPH    10.95"            1X23    260121            360710            260821            360709            16053
[4] 10.95 PRESSURE AND DISC ARE USED IN THIS APPLICATION
How will the 10.95 B&B fit? When I used to have a 10.5" clutch
Are the bolt patterned different
Do I need a new Flywheel?
Help Please   :dunno:
1974 Barracuda, 340cid, 4 speed OD !!
Offline IMNCARN82
  • LeDZeP
Re: Yes another Clutch Question!!!
« Reply #1 on: February 16, 2007 - 08:02:21 AM »
Before I found this site Brewers Performance Inc. Helped me out alot with questions.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #2 on: February 16, 2007 - 02:02:54 PM »
I would use the 10.95 B&B or the B&B / Long
 the 10.95 bolts onto the same flywheel [130 tooth]as the 10.5
Offline matt63
« Reply #3 on: February 24, 2007 - 08:11:30 AM »
It's a good idea to resurface the flywheel when installing a new disc.  I thought that the borg and beck/long clutches would be ideal due to the lower pedal pressure but they are expensive.  If I remember correctly they were more than 50% more than the Centerforce Dual Friction. I guess it depends what you want.
Matt in Edmonton
'68 Valiant
« Reply #4 on: February 24, 2007 - 12:00:19 PM »
Actually when I priced the C force it was far more expensive than the McLeod
Offline matt63
« Reply #5 on: February 24, 2007 - 12:26:19 PM »
Mopac quoted me $750 for the McLeod Long and I paid approx $500 for the Centerforce Dual Friction.
Matt in Edmonton
'68 Valiant
« Reply #6 on: February 24, 2007 - 12:42:07 PM »
Hmm I buy the McLeod for $320 & the disc is 170 range , the c force was over $600
