Author Topic: Fender gills/louvers  (Read 1030 times)
Offline TreeFrog
    • TreeFrog
« on: February 16, 2007 - 07:27:01 AM »
how do I remove paint, or what black (flat, semi, gloss) should I paint the plastic portion of the side louvers (72 Challenger).  The last genius painted them yellow (did not take the time to remove the louvers...
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline Challenger6pak
Re: Fender gills/louvers
« Reply #1 on: February 16, 2007 - 09:43:17 AM »
I use the Rust Olem puff can Satin Black.  Spray several light coats and it won't gloss.  I like it for things like this because wax won't turn it white.  It ends up with a finish very close to the original "naked" black plastic the inserts came from the factory.
Offline TreeFrog
    • TreeFrog
« Reply #2 on: February 16, 2007 - 10:54:06 AM »
what I wory about in part, is the old yellow paint peeling or the black not sticking to the yellow...but I dont know any safe way to take off the yellow paint.
« Reply #3 on: February 16, 2007 - 11:11:01 AM »
There isn't a good way to get the yellow off the plastic.  I have never had trouble with the Rust Olem sticking.  Just get them real clean and dry before spraying.  One advantage of a puff can in this situation is you can have the coats go on thin.  If the plastic isn't real wet with paint the likelyhood of reaction is lowered.  Do you know what kind of paint the yellow is?  Enamel, Laquer, etc.  The Rust Olem is Enamel.
Offline TreeFrog
    • TreeFrog
« Reply #4 on: February 16, 2007 - 11:33:42 AM »
no I do not...someone sprayed the entire car yellow...but I am not paint/body guy...
« Last Edit: February 16, 2007 - 11:35:17 AM by TreeFrog »
« Reply #5 on: February 16, 2007 - 12:47:33 PM »
I would say just try it.  Unless the yellow paint is fresh you should be fine.  You can guess at what kind of paint the yellow is by the use of different solvents.  In this case if you use light coats and space them apart you should be fine.
Offline TreeFrog
    • TreeFrog
« Reply #6 on: February 16, 2007 - 01:48:14 PM »
cool, I will do it!
Thanx!
« Reply #7 on: February 16, 2007 - 06:15:41 PM »
Should only cost $5 and some time. If you haven't ever taken the inserts off the louvers do it slow and evenly.  They will be brittle.  Post a pic and let me know how they come out.
Offline TreeFrog
    • TreeFrog
« Reply #8 on: February 20, 2007 - 01:32:54 PM »
I took the one(only had one whaen we got her) off of the 73 years ago.  It was fun, but not too bad.
