Author Topic: Rack and pinion  (Read 1340 times)
Offline Fooch
Rack and pinion
« on: February 16, 2007 - 01:27:55 PM »
Not sure if this is the right area to put it in, if not let me know and I will move it, but are there any kits or any way to get rack and pinion steering in a '70 Cuda? I heard through a few of my dads friends that it may require modifications to the frame, any truth to that?
-Jared
Re: Rack and pinion
« Reply #1 on: February 16, 2007 - 01:50:04 PM »
there are a few types availble , probably the best is the Alter-K-Tion ,most replace or modify the K frame & if they incorperate coilover front shocks will require frame re-inforcement with the exception of the Alter-K-Tion    , the majority are front steer types which require a different spindle , rear steer types can use the factory spindle
Offline Fooch
Re: Rack and pinion
« Reply #2 on: February 16, 2007 - 02:02:08 PM »
I'll look into that, thanks.  :2thumbs:
Offline 6packCuda
Re: Rack and pinion
« Reply #3 on: February 16, 2007 - 05:10:56 PM »
Unisteer makes a rack and pinion kit for e-bodies that is "supposed" to bolt in with out modifying the k-frame. I'm considering it for my 70' as well.
Re: Rack and pinion
« Reply #4 on: February 17, 2007 - 09:22:30 AM »
I've heard the Unisteer system is kind of pricey at $1500-1800 and may cause some bump steer problems. Never looked at it myself though. One of the biggest problems with a rack set up is oil pan interference and locating the rack without cutting into and requiring a different oil pan.
You can get great improvements with a Firm Feel unit, but you still have to deal with the weight.
Offline matt63
Re: Rack and pinion
« Reply #5 on: February 17, 2007 - 09:46:41 AM »
The Alterkation kits start at $3000. https://www.reillymotorsports.com/store/home.php
Matt in Edmonton
'68 Valiant
Offline ragtopdodge
Re: Rack and pinion
« Reply #6 on: February 17, 2007 - 11:15:05 AM »
I would not do the Unisteer system until you have heard LOTS of reports from folks that it works well.
The ALter-kation has been proven over and over of working in street applications; not just on the 1/4 track.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
