Author Topic: 1 inch lower on the driver's side, any suggestions on the troubleshooting?  (Read 1712 times)
Offline banana70
  • 70/440 and 74/318 challengers
 :working: somehow mi car is almost a full inch lower on the driver's side... I think is the rear suspension.
Don't know how to "adjust" it or play with it..
leaf srings?... shackles?... shocks?..  what can it be?...  twisted frame??  .. or maybe just an front under arm graduation.?  :working:
thank you
Offline AMXguy
Re: 1 inch lower on the driver's side, any suggestions on the troubleshooting?
« Reply #1 on: February 16, 2007 - 08:34:45 PM »
 The first thing I'd do is adjust the front end level, if you're still off in the rear it's probably springs.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
nivvy
« Reply #2 on: February 16, 2007 - 09:12:32 PM »
I had problems adjusting my 72 chally....kept adjusting torsion bars... took a while for me to figure out that my garage floor was tapered for drain runoff...pulled the car out of the garage on a level surface and adjusted from there and all was fine...  :burnout:
« Reply #3 on: February 17, 2007 - 09:19:42 AM »
What leaf springs do you have? If Super stock, then that is normal and it is deisnged that way to absorb torque and provide a straight launch.
Offline banana70
« Reply #4 on: February 17, 2007 - 09:58:38 AM »
thanks stroker and hp2...
since that's how i got the car I Don't know if SS... is there a way to know? any part nbr?
she's higher than normal on the back and I'd like to lower that rear and make the car parallel to the street, .. would stock leafs help me there? how about those spacers they sell to lower the ride?...
The car has the adj pinion snuber and I took the pin away so it;s at the lowest position.
Offline ragtopdodge
« Reply #5 on: February 17, 2007 - 11:17:38 AM »
Spacers will work, but I wouldn't do more than 1".  More than that and you can have too much axle rap up for hard launches.
New springs from ESPO ain't that expensive.  Might just want to get new springs.  Ask for the STOCK height as these usually are saggy looking anyways.  You still want a rake, so lower the front.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
nivvy
« Reply #6 on: February 17, 2007 - 11:59:51 AM »
I put Superstock springs on my 72 challenger part#mopp4120865/4120866 (left&right) but what helped lower my car was the front springer hanger in the relo kit has an upper and lower mounting holes...of course I used the upper holes to lower the car..
the tires are 28" tall..........
Offline heminut
« Reply #7 on: February 20, 2007 - 08:33:13 AM »
Sounds like it's a good possibility you have the superstock springs. I have them on my Cuda and with the stock springs on the car there is not enough room for the adjustable pinion snubber, and with the S/S springs there is. The stock springs have a 22" front spring section, and the S/S springs are only 20". To determine what you have, measure from the center of the front spring eye back to the center of the spring perch.
1970 5.7 Hemi Cuda
Offline 6packCuda
« Reply #8 on: February 20, 2007 - 03:02:17 PM »
I crawled under mine today to see what I have. The front section measures 22 inches, so I guess their stock springs. They have the #P4452984 and P4452985. The drivers side has 6 leaves and the passenger side has 5. Is this to help control wheel spin?
Offline heminut
« Reply #9 on: February 21, 2007 - 10:12:20 AM »
The S/S springs have an extra leaf on the right side and I believe the factory 6 Pack/Hemi springs did too. If yours has the extra leaf on the left side someone may have swapped them from side to side at some time. I don't have the references to look up those part #'s but I'm sure someone here does and will respond. Chryco can tell you which side the even and odd numbered springs should be on. I never could keep that stuff straight, CRS gets worse as you get older! :lol:
1970 5.7 Hemi Cuda
Offline TreeFrog
    • TreeFrog
« Reply #10 on: February 21, 2007 - 10:59:58 AM »
I understood that the HEMI cars has an extra on both sides...but that may be wrong.
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
« Reply #11 on: February 21, 2007 - 11:42:27 AM »
6pak, those numbers are for the factory XHD springs, or Hemi springs as they are commonly called. The 984 goes on the right, 985 on the left. The are a biased design to control torque reaction during launch.
Banana, see the above posts for determining if you have stock, XHD, or SS springs. After 30 years, it could be any or none of the above that have given you your current ride height.
