Need to re-gear the speed-o
Author Topic: Need to re-gear the speed-o  (Read 3425 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: February 18, 2007 - 08:37:36 AM »
I have a 70 'Cuda with 727 3.23 rear gear.What teeth size speedometer gear should I use?
My rear tire are 275/60-15 (Tire Diameter 28.00 inch). But I'm getting 255/60-15 (Tire Diameter  27.00 inch).
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Re: Need to re-gear the speed-o
« Reply #1 on: February 18, 2007 - 08:50:13 AM »
I can narrow it down a little. I have the same tire size on my rear, but I thought they were 26".  :clueless: In any event, I went with 34 teeth, and it is dead on.
Offline tactransman
« Reply #2 on: February 18, 2007 - 09:01:41 AM »
Terry-tactransman
Union, Mo.
« Reply #3 on: February 18, 2007 - 09:17:10 AM »
Take a look at this link :thumbsup:
http://www.moparts.com/Tech/tech/pages/speedo.html
See, that's where I get confused. That chart says 33 teeth BUT it's for a 3:21 rear. Who here has a 3:21 rear?  :screwy: 33 teeth had me 4-5 MPH too fast, so 34 did the trick. Sorry to vent.  :-[
« Reply #4 on: February 18, 2007 - 09:41:48 AM »
calculator I found .. 255/60/15 tire & 3.23 gear gives 31.31 teeth, 31 teeth pinion = part # 52068153(green)
http://www.moparts.com/Tech/tech/img/AUTOMATICchart.xls
Teeth Color Part Number
27 (white) 52068149
28 (blue)  52068150
29 (black) 52068151
30 (yellow)  52068152
31 (green)  52068153
32 (black) 52068154
33 (yellow) 52068155
34 (green) 52068156
35 (orange)  52068157
36 (red) 52068158
37 (white)  52068159
38 (blue) 52068060
39 (green) 52068061
40 (orange)  52068062
« Last Edit: February 18, 2007 - 09:48:55 AM by bullitt99 »
Offline 70challengerrt
« Reply #5 on: February 18, 2007 - 10:04:40 AM »
Year one has a chart that matchs tire size to rear end gearing. According to the chart you need 33 tooth gear (yellow gear) year one part #FD033. I went off the tires you are going to run 255/60 R15.
Todd
Offline widing'cuda
« Reply #6 on: February 18, 2007 - 01:45:01 PM »
Thanks guys I'll get myself a 33 and 34 and see what turns out the best. Is it easy to swap them. Never done this before.  Will I loose lots of transmission oil?
Offline tactransman
« Reply #7 on: February 18, 2007 - 02:04:31 PM »
Jack the back of the car way up,all the fluid will go to the front,piece of cake. Make sure you "index" the speedo bullit correctly. Speedo gear number group goes down.
Terry-tactransman
Union, Mo.
Offline widing'cuda
« Reply #8 on: February 18, 2007 - 02:50:53 PM »
How do I do that?
« Reply #9 on: February 18, 2007 - 03:28:50 PM »
How do I do that?
Good question. When i bought my car, it had a 26 tooth gear in it. I was reading 90 at 60 MPH.  :dupe: You might notice outside the gear housing, there are numbers for gear ranges. The range gear you want(33,34) needs to be at the bottom. I didn't tilt my car, and probably lost almost a quart of tranny fluid when I did the swap. Have a pan ready.  :thumbsup: Believe it or not, tranny fluid stinks.  :eek4:
Offline inot2old
« Reply #10 on: February 18, 2007 - 07:35:55 PM »
I need to do that too.  My speedo shows about 80 at 60.  I know somebody has changed the gearing in my car but didn't change the speedo gear. :stomp:
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
Offline widing'cuda
« Reply #11 on: February 19, 2007 - 10:43:54 AM »
Ok... I think I get it. Min is showing 90 mph in 60 mph as well. I won't do it before in the spring time (April/May).
Offline heminut
« Reply #12 on: February 20, 2007 - 08:20:18 AM »
It also doesn't wash out of white T-shirts either!!! :scared:  :roflsmiley:
1970 5.7 Hemi Cuda
