Does oil have a shelf life?
Author Topic: Does oil have a shelf life?  (Read 1610 times)
Offline Katfish
  • 70 Challenger
« on: February 18, 2007 - 05:29:38 PM »
My mom gave me 3 cases of oil she found in her shed.  I would guess it could be anywhere from 1-5yrs old.
Does oil go bad?
Thx
Offline 67vertman
  • Member since 9-23-2005
Re: Does oil have a shelf life?
« Reply #1 on: February 18, 2007 - 07:37:26 PM »
All though they don't put an exasperation date on oil cans, it’s typically an industry standard that the shelf life of motor oil is 5 years.
What are you going to use it in?  Probably still good for a lawn mower or such, but I would have second thoughts about using it in my car.  :2cents:
Offline jeryst
« Reply #2 on: February 18, 2007 - 09:40:19 PM »
Learn something new every day. I always figured that since it sat in the ground for millions of years, it would last in a can forever.
What happens to it? Does it separate, lose viscosity, or something else?
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #3 on: February 19, 2007 - 12:49:22 AM »
 :popcorn:
Offline JRoss22
  • Member Since 05/08/2005
Offline Katfish
  • 70 Challenger
« Reply #5 on: February 19, 2007 - 03:01:16 AM »
Thx guys, 5 yrs it is.  Too bad Mobile didn't give explanation.
Offline mopower
« Reply #6 on: February 19, 2007 - 07:08:15 PM »
2 million years,fossil fuel :droolingbounce: :dogpile:
Offline 67vertman
« Reply #7 on: February 19, 2007 - 08:52:18 PM »
Because crude oil is made up of a mixture of hydrocarbons, this first and basic refining process is aimed at separating the crude oil into its "fractions," the broad categories of its component hydrocarbons.  Crude oil is heated and put into a still -- a distillation column -- and different products boil off and can be recovered at different temperatures.  The lighter products -- liquid petroleum gases (LPG),  naphtha, and so-called "straight run" gasoline -- are recovered at the lowest temperatures.  Middle distillates -- jet fuel, kerosene, distillates (such as home heating oil and diesel fuel) -- come next.  Finally, the heaviest products (residuum or residual fuel oil) are recovered, sometimes at temperatures over 1000 degrees F.   The simplest refineries stop at this point.  Most in the United States, however, reprocess the heavier fractions into lighter products to maximize the output of the most desirable products
Additional processing follows crude distillation, "downstream" (or closer to the refinery gate and the consumer) of the distillation process.   Downstream processing is grouped together in this discussion, but encompasses a variety of highly complex units designed for very different upgrading processes.  Some change the molecular structure of the input with chemical reactions, some in the presence of a catalyst, some with thermal reactions.
In general, these processes are designed to take heavy, low-valued feedstock -- often itself the output from an earlier process -- and change it into lighter, higher-valued output.  A catalytic cracker, for instance, uses the gasoil (heavy distillate) output from crude distillation as its feedstock and produces additional finished distillates (heating oil and diesel) and gasoline.  Sulfur removal is accomplished in a hydrotreater.  A reforming unit produces higher octane components for gasoline from lower octane feedstock that was recovered in the distillation process.   A coker uses the heaviest output of distillation, the residue or residuum, to produce a lighter feedstock for further processing, as well as petroleum coke.
Offline BIGSHCLUNK
« Reply #8 on: February 19, 2007 - 09:13:45 PM »
 :2cents: lets just say there's oil I'd run in  my wife's Prizm that I wouldn't run in NIKKi
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline jeryst
« Reply #9 on: February 20, 2007 - 10:29:36 AM »
My question still goes unanswered. After 5 years, what happens to it that makes it "bad"?
Offline Blackcuda
« Reply #10 on: February 20, 2007 - 11:58:31 AM »
Might be good in a salid... :crazy:
Offline 67vertman
« Reply #11 on: February 20, 2007 - 09:12:38 PM »
In general, liquid lubricants (ie. oils, not greases) will remain intact for a number of years. The main factor affecting the life of the oil is the storage condition for the products. Exposure to extreme temperature changes, and moisture will reduce the shelf life of the lubricants. As years pass, unused engine oils can become obsolete and fail to meet the technical requirements of current engines. These specs get updated regularly based on new scientific testing procedures and engine requirements. But this is only really a concern if you've bought a brand new car but have engine oil you bought for the previous car. An oil that is a number of years old might not be formulated to meet the requirements set for your newer engine
The following are signs of storage instability in a lubricant:
Settling out of the additives as a gel or sticky liquid
Floc or haze
Precipitates/solid material
Colour change or haziness
Therefore, the oil does not go "bad", it is more a factor of ithe oil not performing as well as fresh / newer oil, or the oil meeting the newest standards.
Offline Pistol Gripper
« Reply #12 on: February 21, 2007 - 06:02:31 AM »
One problem with old oil would be oxidation,  the military adds an anti-oxident to oils & fuel before putting it in long term storage.  I would imagine that oil, over time, will break down chemically like anything else.
P.G.
O ne
B ig
A $$
M istake
A merica
