It' gets a little confusing from here on for me. Lots more questions, and some you didnt answer
Where's the old balancer?
a big rod steel crank balancer for an hp will be external balance, so the balancer will have a small weight attached to it. The fly wheel is a bit different too if it's the external balanced big rod engine. You need to know what you have to install the correct balancer.
so first, you need to know if it's a big rod engine. All hp 440's in 71 had the big rods and was external balance.
What you need is obtainable and probably from a member, but you have to know what to ask for first.
