Author Topic: harmonic balancer  (Read 1387 times)
Offline Stacked440
harmonic balancer
« on: February 19, 2007 - 07:26:15 PM »
I'm not sure I have the right harmonic balancer for my 440, I don't want to start it without knowing, anyone know what to look for or some way to tell if I have the right one?
-Kyle-
1971 Challenger R/T clone 440/5-spd
1973 Duster - 5.7L Hemi swap project
Offline Moparal
Re: harmonic balancer
« Reply #1 on: February 19, 2007 - 09:37:43 PM »
Have you got a big rod engine or regular? Cast crank or steel? Internal or external balance? These are the critical questions if you didnt have the engine balanced.
Offline v8440
« Reply #2 on: February 19, 2007 - 10:00:41 PM »
I second that emotion.  If you don't know the answers to those questions, just tell us about the motor-what year, what transmission came behind it, etc.
Offline Stacked440
« Reply #3 on: February 20, 2007 - 12:08:30 PM »
its a 71' warranty block 440, not sure what crank is in it, it was redone at an engine shop but I don't beleive they did an internal balance on it,  and theres an 833 behind it.
-Kyle-
Offline Moparal
« Reply #4 on: February 20, 2007 - 04:37:26 PM »
It' gets a little confusing from here on for me. Lots more questions, and some you didnt answer
Where's the old balancer?
a big rod steel crank balancer for an hp will be external balance, so the balancer will have a small weight attached to it. The fly wheel is a bit different too if it's the external balanced big rod engine. You need to know what you have to install the correct balancer.
so first, you need to know if it's a big rod engine. All hp 440's in 71 had the big rods and was external balance.
What you need is obtainable and probably from a member, but you have to know what to ask for first.
Offline Stacked440
« Reply #5 on: February 21, 2007 - 06:20:55 PM »
I have a harmonic balancer on it, I'm just curious as to whether it is the right one, I don't want to tear my engine apart when I go to start it because I have the wrong one :pullinghair:
-Kyle-
Offline Challenger6pak
« Reply #6 on: February 21, 2007 - 07:07:55 PM »
You will have to find out what's in it in order to balance it correctly.  You can't always go by the block date.  Any of the internal componets may have been changed.  These determine which converter balance you will need.
« Last Edit: February 22, 2007 - 04:57:51 AM by Challenger6pak »
Offline Stacked440
« Reply #7 on: February 21, 2007 - 08:33:31 PM »
So where or how can I tell if I indeed have the correct weight or size etc?  I have no idea what kind of internals are in the motor because it was re-built by an engine shop and came with the car when we bought it 2 years ago.  It has a 6 bolt crank but other than that It is a mystery :dunno: :stomp:
-Kyle-
« Reply #8 on: February 22, 2007 - 04:54:56 AM »
Is the motor in the car?
Offline Stacked440
« Reply #9 on: February 22, 2007 - 09:47:19 AM »
no, its on a stand
-Kyle-
« Reply #10 on: February 22, 2007 - 12:21:58 PM »
You'll have to pull the pan and look at the crank and rods to figure out what you have.  If you don't know what you have post a pic.
Offline Stacked440
« Reply #11 on: February 22, 2007 - 09:38:54 PM »
Alrighty...I guess ill make a point to do that tomorrow...
-Kyle-
Offline Moparal
« Reply #12 on: February 22, 2007 - 09:52:39 PM »
Did the machine shop balance your engine? They should know something about it. Good luck
Offline chevyconvert
  • HvacMan
« Reply #13 on: February 22, 2007 - 11:06:06 PM »
 :popcorn:
Eric
Bay Area California
Offline Stacked440
« Reply #14 on: February 23, 2007 - 09:30:59 AM »
I'll have to dig through all the receipts, It's in Chattanooga, TN.  So walking down to the shop isn't an option :lol:  Well, I have some things to do today, i'll give the info I find on the receipt before I pull the pan( don't wanna buy another gasket! :eek4:
-Kyle-
