David:
I have been on vacation, but just returned and saw your post. If you haven't already gotten it painted, you can have a look through my old thread (
http://www.cuda-challenger.com/cc/index.php?topic=28698.0). You will need to patiently look through the several topics I brought up, but there is some good information there.
Also, you might want to have a look at the article from 'Mopar Performance News' that Challenger6pak attached to this post:
http://www.cuda-challenger.com/cc/index.php?topic=28832.msg290465#msg290465I am getting mine painted this week, and I
think I understand it now:
1) The engineering drawing (on Barry's site) gives exact measurements, and shows how to locate the stripe, but nobody knows where the location dimensions are measured from. But you can definitely see that the front stripe is 0.20", then a 0.25" gap, then the rear stripe extends to the rear of the panel.
2) That article in 'Mopar Performance News' mentions that the total thickness (both stripes plus gap) is 5.70", measured at the edge of the trunk lid. That article also mentions the same stripe thickness that is shown in the engineering drawing. I am using that as a guide, and sort of 'eye-balling' how the stripe wraps around the quarter panel.
3) The color is still confusing for me. That MPN article mentions 'a satin finish, not gloss'. But the consensus around here seems to be that gloss was used (mine will be black, so it is PPG 9000). When most people paint them, they use a satin-type paint, similar to the decals on the B-body bumblebee stripes.
When you get yours taped out, let's compare notes! Good luck.
Tom
