Author Topic: Cast exhaust manifolds & serious power?  (Read 676 times)
Offline ArcticCuda
    • Pepe
« on: February 21, 2007 - 04:02:11 AM »
My question is that is there anybody out with cast exhaust manifols & serious power?
I have TF 727 and 3.55 gears. New engine will be as follow; 383 block, 3.75" crank, H-beam rods and Ross ft-pistons. I want to get my Cuda in 12's and still keep my cast hp -manifolds and resto look. How about heads, cam and converter?
Thanks Pepe
« Last Edit: February 21, 2007 - 04:07:13 AM by ArcticCuda »
Current Vehicles:
Plymouth PPR Cuda 1970 489 cid
Plymouth GTX 1970 RS23V0E
Sorry my bad english...I'm just an european...
Re: Cast exhaust manifolds & serious power?
« Reply #1 on: February 21, 2007 - 09:02:47 AM »
I built an all stock looking 440+6 with manifolds & made 520 gross HP on the dyno , similar powered cars are well into the 12s but not low 12s
Offline KellysCuda aircard
  • Its good to be blown
« Reply #2 on: February 21, 2007 - 09:21:42 PM »
Wouldnt a step up in gearing really help? Like 3.90 wouldnt that really help?
Offline ArcticCuda
    • Pepe
« Reply #3 on: February 21, 2007 - 11:02:48 PM »
I wanna keep my 3.55 gears.
CP, have you built engines with cast iron manifols & Edelbrock/Indy heads?
Current Vehicles:
« Reply #4 on: February 21, 2007 - 11:55:42 PM »
The big blocks make torque & I have not found very sifgnificant difference with gearing , I have built 3 engines with eddy heads all with headers & none making stellar power so either I am getting great power from Iron heads which 90% of my customers prefer to use as they are doing street resto builds or I am missing something with the eddys heads as I have yet to see significant gains using them , with the indy heads once you are serious enough to get them you won`t be bolting manifolds on them in 99.9 % of the builds
