Sorry, I just use 30wt oil. It tends to "cling" well, and I preoil turning the engine, so they will have oil before it fires. You will want to be very careful about pushrod length, pushrod to head clearance, and retainer to rocker clearance too. the higher the ratio, the more they tend to rub the pushrods on the heads. I have the pushrod holes milled a little taller for that reason on aluminum heads.
