Author Topic: Challenger Front Valence Molding  (Read 3544 times)
Offline RusTy/SE
  • Just havin' fun
« on: February 22, 2007 - 02:22:27 PM »
 I plan to locate a used 72-74 molding to see if it will mount on my 70 front valence. If it does they can be obtained for a fraction of the cost of the two-piece 70 molding while looking just as good on a driver. Has anyone tried this? :dunno:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Re: Challenger Front Valence Molding
« Reply #1 on: February 22, 2007 - 03:12:30 PM »
Russ,
  Being 'tupid back in the day, I tried this. It didn't go well for me.  :pullinghair: It just didn't fit right. On the other hand, I remember someone on here saying they got theirs to fit well(maybe ROBB). I know the 72-74 moldings are heaps cheaper, but even they don't come around often. I know... I didn't help you out any. Sorry.  :bricks1:
« Reply #2 on: February 22, 2007 - 04:05:25 PM »
Russ, I'm pretty sure I saw the 2-pc trim being reproduced but was unable to find again. I will keep an eye pealed for this.
Wade
  EDIT
MY mistake it was a 72+ grill trim
How bad is yours, maybe spend your $s having it restored.     Can't you just do without this piece anyway?  :clueless:
« Last Edit: February 22, 2007 - 05:39:05 PM by bullitt99 »
Offline Challenger6pak
« Reply #3 on: February 22, 2007 - 05:33:14 PM »
Rusty, here we go again.  LOL.  I believe there is more "meat" for mounting provision on the 72 up front valance than the 70-71 front valance.  I will pull out a couple and look tomorrow.  The 72 molding may not work on the 70 valance.  Before I get rid of all these parts I need to photograph the differences anyway.
Offline RusTy/SE
  • Just havin' fun
« Reply #4 on: February 22, 2007 - 06:55:36 PM »
Russ,
It's all good MEKy-D :smokin:
I was able to score a decent set last year through ebay and would like to have something up there. That's the reason i was curious about using the later valence molding. If it doesn't work out, i plan to go without the valence moldings, as well as the wheel opening moldings, until after the car is done then have the used 1970 pieces i've accumulated restored. It'll cost a few extra ducats but that's ok :)
I remember the 72-74 molding having a deeper mount area - just not sure how compatable would be with my 70 valence. I did try a test fit with the used original 70 valence moldings and it was very nice. Thanks man :thumbsup:
« Last Edit: February 22, 2007 - 07:03:49 PM by RusTy/SE »
Russ
2001 Durango     1B4HS
Offline 70RTdroptop
  • 1970 Challenger R/T 440-SixPack
« Reply #5 on: February 22, 2007 - 07:51:06 PM »
I thought I saw an ad in Mopar Muscle 4 -5 months ago about the '70 Challenger front valence molding. I believe it was PG Classics that was re-popping these pieces. Haven't seen them advertised lately though. Maybe their website has them. I'd also be curious about this molding, as I could use one too. Mine's probably saveable, but depends how much it'll cost.
1970 Dodge Challenger R/T 440-6 convertible
1966 Ford Mustang convertible  - numbers matching (wife's car )
Offline ragtopdodge
« Reply #6 on: February 22, 2007 - 10:19:38 PM »
I thought all Challenger valences were the same. :clueless:
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #7 on: February 23, 2007 - 07:32:36 AM »
There are a few differences between 70, 71 & 72 -74 front valance pan.  The 72 - 74 has mounts added on the 3 brackets that attach it to the car. These are for the lower grille piece.  There are 2 mounting provisions added to the front lip of the pan also. Other mounting holes, for the molding, were just enlarged on the 72 - 74  pan. The orange pan is a 70, 71; the other a 72-74. You could mount the newer molding on the 70 - 71 pan.  You would have to add mounts to mount anything else.  For a stock look a 72 - 74 pan could be used on any Challenger.  A 70 - 71 would work the best on a 70 or 71 Challenger.
« Last Edit: February 23, 2007 - 07:35:31 AM by Challenger6pak »
Offline RusTy/SE
  • Just havin' fun
« Reply #8 on: February 23, 2007 - 09:12:50 AM »
  Thanks Challenger6pak...your explanation along with the pictures just cleared up another gray area for us. Way cool :thumbsup:
Russ
 :cheers: :cheers:
Russ
2001 Durango     1B4HS
